Framework 16 Ethernet doesn't work after sleep mode
Info
Windows 11 Pro 25H2
Framework 16 AMD Ryzen AI 9 HX 370 w/ Radeon 890M & w/ Nvidia 5070 GPU
32.0 GB ram
Issue
I am having an issue with my ethernet expansion card where after sleep mode in windows the card does not work when I plug an ethernet cord in. No lights, no connection in windows.
If I unplug the expansion card (not the cord, the entire card) and plug it back in it works again until I put the computer to sleep by closing the lid again.
I too would like to know this as well. I use a UGREEN Steam Deck dock and this always happens. If I turn on the laptop and simply use only wifi it says the ethernet is available but not connected - great. If I connect it, it will say that ethernet is connected. If my laptop sleeps, I connect it to the dock that has the ethernet connected, turn it on, it doesn’t recognize that. By that I mean that it doesn’t even have the message along the lines of “Ethernet is not connected” as if it never heard what an ethernet cable is. It’s as if the drivers for the ethernet capability was temporarily removed. While I don’t have the ethernet expansion, this issue is still relevant to me for a few months now. The only way to fix it is to restart the laptop. It’s really annoying. I’ve already tried unplugging the dock cable from the laptop from both the laptop side and from the dock side. I did the same thing for the ethernet cable from the dock as well as the power cable. Nothing works other than a restart.
i have the same Problem after install nividia card and update BIOS and driver. When I disconnect the Adapter it works until several minutes and disconnect again.
I also am experiencing this issue, where after reboot of the system, Expansion slots 2 and 3 on the left side seem to be disabled and need to be unplugged and plugged back in.
I have tried a reinstall of windows, and updating BIOS drivers and using the framework video drivers, still same isssue.
This started at some point randomly about 6 months to a year ago, and just gets more and more annoying the longer it goes on, thus why I am now posting.
I don’t know if it was a windows update, or a bios update, but at some point, it started happening without any physical hardware change.
I have the same issue. My ethernet and sometimes USB-A adapters don’t work after waking up from sleep mode.
It seems like this option, “Allow the computer to turn off this device to save power” is enabled by default in the Device Manager.
Ever since I disabled it, I haven’t run into this problem.
