Framework 16 keyboards
Hi,
When I look at the Framework marketplace for Framework 16 keyboards. Some of the pictures are wrong. For example, if you click on the “British English” keyboard, the pictures associated with it are not the UK / British layout.
This leaves me with some confusion as to whether the keyboard I order will turn out to be correct.
You mean when you click the British layout from the marketplace? Initially, it can just bring you to the default.
You need to select your layout from the “Select Keyboard” drop-down box on the right.
Ah! Ok, but it is not so obvious when viewing the page on a mobile phone, because the keyboard selection drop down is off the screen, and one needs to scroll down quite a bit to see it.
But, thank you for pointing out the drop down menu, so I am not so confused now.
