Framework Desktop Ryzen AI MAX 300 BIOS 3.05 Release BETA
Highlights
  1. Added support for new LPDDR5 128GB modules.
  2. Resolved an issue causing slow boot times in GRUB and Linux environments.
Please note: With BIOS 3.05, you can downgrade to a previous version.
You can check your current BIOS version following the steps here to determine if you are on the latest release.
After the beta release, we will monitor community feedback, and publish this release to our stable release channel after approximately one week if no major issues are reported.
Subscribing to release notifications
If you want to subscribe to new release notifications you can now opt in through this link to receive an email when we release a new BIOS or driver update for your Framework Desktop.
Downloads
Windows
Download Link SHA256
Framework_Desktop_Ryzen_AI_MAX_300_BIOS_3.05.exe 63ACEE93113853AB6911C68470EAA927A87D9D781A6B65748DF368C2155B5554
Please do not interrupt power to your desktop while the update is in progress.
Instructions for Windows Installer:
  1. Run the .exe.
  2. Click yes to reboot.
  3. Wait for the firmware progress bar to complete, and then the system will reboot.
Linux/LVFS
Updating via LVFS is available in the testing channel during the beta period.
You can enable updates from testing by running
fwupdmgr enable-remote lvfs-testing
Please note that you must update with a charger attached, then run::
fwupdmgr refresh --force
then
fwupdmgr get-updates
then
fwupdmgr update
Linux/Other/UEFI Shell update
Framework_Desktop_Ryzen_AI_MAX_300_BIOS_3.05_EFI.zip F576D857A27C847B8C07A62EA83811F7AAE8F35422559AA39AC6600CAC52415C
Note that if you use the EFI shell update with Windows, you should suspend Bitlocker if enabled before updating using the EFI updater.
Instructions for EFI shell update:
  1. Extract contents of zip folder to a FAT32 formatted USB drive. Cleanly unmount the drive before physically removing it, otherwise the BIOS update may not function correctly.
  2. Set the ESP flag for the FAT32 partition.
  3. Boot your system while pressing F12 and boot from the thumb drive.
  4. Let startup.nsh run automatically.
  5. Follow the instructions to install the update.
Security Fixes
N/A
Enhancements
Fixes
  1. Resolved an issue causing slow boot times in GRUB and Linux environments.
Component Versions
This BIOS update is a bundle of updates to multiple embedded components in the system.
Not all of them use the same version number.
BIOS 3.05 Updated
EC ec_305_038b483 Updated
PD 0.0.0E Same
AMD PI StrixHaloPI-FP11 1.0.0.2 Same
Reporting Issues
To report issues we have created a public issue tracker on github. Issues · FrameworkComputer/SoftwareFirmwareIssueTracker · GitHub We hope that this is a better way to track issues with community involvement moving forward as we have found it difficult to both gather relevant information about issues people are reporting on the forums, and track the issues through their lifecycle in a transparent way.
If you do experience an issue with the update that is related to your system firmware, please post as complete a description as you can, including relevant system information, and external peripherals. Please note that we do not currently have a SLA for responding to issues on github, but we will be reviewing them through the bios release process, and will review them for future updates as well.
If you have an issue regarding hardware, broken devices, returns, etc, this is not the place, please contact support.
Known Issues
  • Certain USB-C peripherals may exhibit intermittent compatibility issues during the PD or DisplayPort Alt Mode handshake.
Cannot get this to install via fwupdmgr on linux, I have tried removing the cache, forcing refreshes and disabling the default lvfs remote to no avail.
“Added support for new LPDDR5 128GB modules.”
What does this mean? Was V3.05 beta was previously only available for 32/64gb mainboards but now for the 128 versions as well?
Maybe newer Desktop hardware revisions have different modules?!
The boot process is now back to normal and is as fast as before….. YEAAHHH :slight_smile:
This messages are shown after initialization of the kernel -image ram-disk.
Slow boot issue seems to be fixed with the new BETA bios.
Fixed slow boot issue on Cachy OS. Now I can update my os every few minutes.
any work around resolutions for the usb c pperipherals having intermittent compatibility issues? My right side port died and wont let me charge there anymore. if I plug my phone in, it will buzz with haptic feedback periodically letting me know it started to charge and then stopped.
Edit: spelling correction
Downgrade to 3.04 and wait for a fix to be released
I’ve been on 3.04 pretty much since this release because i use a usb-c monitor and having to reboot multiple times until it decided this time it was going to work…. was just not my cup of tea. reverting to 3.04 solved my problem.
of course if you’re on GRUB instead of systemd boot….. then maybe you’ll eant to go back to 3.03 instead….. or switch to systemd boot cause the GRUB boot times for 3.04 are……. something special.
Is this going to be fixed before 3.05 final or will we have to wait until the next release? I’m also using USB-C cable for the display.
@Quin_Chou would you please explain more on what’s happening here?
Darn, the USB-C handshake thing wasn’t part of the explanation in fwupdmgr, so now my USB-C screen stopped working.
Oh well, downgrading with fwupdmgr downgrade
I only upgraded the bios because I was having very sudden issues with screens today after I tried to use a HDMI TV (which worked flawlessly before) and it suddenly started to have very weird issues, like my screens freezing and unfreezing randomly (sometimes even just one screen just freezing), or all the screens freezing hard while sound continues, with the only way forward being reset (sysrq reisub worked just fine though). I also suddenly get hrtimer messages like interrupt took 9898 ns which is really odd…
We have received reports that certain devices are failing to initialize. After analyzing the PD protocol logs, we identified that the failures occur during the initial handshake between the device and the host. It appears the communication is dropping before the power contract is finalized. This issue is reported on previous firmware version, so we listed on the known issue. While this appears to be a device compatibility issue, we are currently investigating whether the root cause is a non-compliance with PD specifications or a separate logic error within the host controller.
Thanks for explaining it.
On BIOS 3.03 and 3.04, I haven’t noticed my USB-C SSD and monitor failing to initialize yet. I will give BIOS 3.05 a try when I’m able to (currently using my pc for work).
A wild guess, could it be some devices trying to draw > 7.5W on boot and causing that issue? For example HDDs tend to draw large current when spinning up.
@Quin_Chou After upgrading my bios to the beta 3.05 version, the rear USB ports stop working when returning from suspend. I have my mouse and keyboard connected to those ports and have to move them to the front USB ports so I can restart my computer. I see similar reports of this behavior but seem unrelated to the bios version, although for me they seemed to have started post bios update.
I am using cachyos. I reverted to the LTS kernel just in case it was kernel related and I’m still seeing the issue,
I am downgrading back to 3.04 to fully confirm it’s bios related.
Confirming that the issue is not present in 3.04
Definitely not Framework’s ineptitude?
