Got it working normally on latest kernel 6.15.4. The speed is much much better and no disruptions in connection.
As usual, @jwp speaks with great wisdom. I had accounted for reg, did not consider router time/date - excellent suggestions!
This is excellent news! Can you describe the following, for my own tracking?
Distro (assuming Fedora or Arch)
Any changes made to your configuration besides package update with new kernel?
RZ717 (MT7925) Mediatek wireless
Router brand/model
Band you had success connecting to (2.4, 5ghz, 6ghz, etc)
Thank you!
I am on the same chipset and on the same kernel on Fedora, but, my magical mesh network never has these issues, so I rely on others for repro fails/successes. ![]()
- It is Ubuntu 24.04
- No changes made apart from upgrading kernel to version 6.15.4. I just installed Ubuntu the day before
- MT7925a chipset
- Unfortunately, canāt say. It was public Wi-Fi at office.
- 2.4 and 5ghz. Didnāt try 6ghz.
I finally captured the logs when the Wi-Fi issue occurred. It happens quite randomly, and in many cases, the test script wasnāt even running when the problem happened.
In the last few log entries, the RX packet count didnāt seem to increase. At that moment, I noticed that webpages on the computer stopped loading. I then checked on my phone and confirmed that the laptop was no longer connected. Since I needed to get things done, I stopped the script and restarted the Wi-Fi.
Also having problems on NixOS with Kernel version 6.15.4 on the MEDIATEK Corp. MT7925 (RZ717).
On my home wifi I can only access ipv6, while ipv4 doesnāt reach anything.
16:07:59: RX bitrate drops from ~200+ Mbps to 1.0 Mbps (TX stays at 229.4 Mbps)
16:08:09: RX bitrate recovers to 229.4 Mbps (TX drops to 172.0 Mbps)
16:09:09: TX bitrate crashes to 6.0 Mbps (RX stays at 229.4 Mbps)
16:09:19 onwards: RX bytes freeze
Ping data shows: 2 packet drops/timeouts during the monitoring period
- RX and TX are failing independently at different times
- The connection stays āupā (still shows connected) even when data transfer stops
- The device remains on the same frequency/channel throughout
- Signal strength stays consistent (-37 to -41 dBm)
First thing I want to check for is a kernel update. Iām on another distro, using 6.15.6 which works well here.
2.4ghz is going to be super congested, so you may also be dealing with heavy congestion.
- Asymmetric failures (RX/TX affected separately) - common with interference
- Data flow stopping while connection stays up - typical of congested channels
- Erratic bitrate changes - interference causes constant rate adaptation
See what other networks are on 2.4 GHz
iw dev wlp192s0 scan | grep -E "(freq: 24|SSID:)"
Check if your AP supports 5 GHz
iw dev wlp192s0 scan ssid "DoraAP"
Force 5 GHz if available
sudo iw dev wlp192s0 connect "DoraAP" 5180 # or other 5 GHz freq
Outside of that, Iād encourage you to open a ticket and weāll gather general logs. Do link to this thread when filing a ticket.
I was not doing network bandwidth testing when running the script, just regular coding, viewing websites, maybe downloading files, so Iām not sure if the bitrate is supposed to stay consistent.
My AP supports both 2.4 GHz and 5 GHz, it shows freq: 5785.0 and freq: 2412.0.
When I run iw dev wlp192s0 scan ssid "DoraAP"
There is an error
command failed: Operation already in progress (-114)
Maybe itās caused by NetworkManager. I tried connecting through the GNOME UI instead, and it connected to 5 GHz just fine.
Connected to a6:0b:6a:c8:9a:7c (on wlp192s0)
SSID: DoraAP
freq: 5785.0
RX: 6359586 bytes (6125 packets)
TX: 807492 bytes (2384 packets)
signal: -37 dBm
rx bitrate: 1080.6 MBit/s 80MHz HE-MCS 10 HE-NSS 2 HE-GI 0 HE-DCM 0
tx bitrate: 1200.9 MBit/s 80MHz HE-MCS 11 HE-NSS 2 HE-GI 0 HE-DCM 0
bss flags: short-slot-time
dtim period: 2
beacon int: 100
I could check other networks on 2.4 GHz and open the ticket next time I encounter the issue. I am also on 6.15.6 right now.
Iām running non fedora 42 and usnig Unifi wifi 7 APs (one pro and one pro wall). Iāve narrowed the majoirty of the problems i have to MLO. I have two SSIDs one with MLO enabled, and when connected to MLO itās connecting to 6ghz and 2.4ghz simultaneously (not sure why not 6 and 5). 2.4ghz signal is.. pretty spotty in my house. I live in a city and thereās a ton of interference. If I switch to the non-MLO SSID and it connects to just 6ghz or 5ghz depending on range, the connection is far far more stable.
In hopes that itās useful to someone, I had intermittent wireless issues for a while but now it seems stable. I assume some standard upgrade along the way helped. Hereās my system:
# System Details Report
## Report details
- **Date generated:** 2025-08-10 12:58:53
## Hardware Information:
- **Hardware Model:** Framework Laptop 13 _AMD Ryzen AI 300 Series_
- **Memory:** 48.0 GiB
- **Processor:** AMD Ryzen⢠AI 9 HX 370 w/ Radeon⢠890M à 24
- **Graphics:** AMD Radeon⢠Graphics
- **Disk Capacity:** 2.0 TB
## Software Information:
- **Firmware Version:** 03.04
- **OS Name:** Ubuntu 24.04.3 LTS
- **OS Build:** (null)
- **OS Type:** 64-bit
- **GNOME Version:** 46
- **Windowing System:** Wayland
- **Kernel Version:** Linux 6.14.0-27-generic
I can try to gather more data if that would be useful.
FW13, AMD AI 7 350
Mediatek wifi card.
I installed Ubuntu 25.04, prepared to upgrade to a more recent mainline kernel based on this and similar threads. But didnāt have to bother so far. 5 days and not a single wifi network drop.
Kernel is unchanged for recent Ubuntu 25.04 iso download: 6.14.0-27-generic.
After installation I did nothing to get anything running besides doing apt upgrade and fwupdmgr get-updates.
fwupdmgr:
Laptop 13 AMD Ryzen AI 300 System Update:
New version: 0.0.3.4
So either Ubuntu already has some backported drivers in current 25.04 or the drops are specific to access points - so far I only connected to 5 GHz. Or I was just lucky for 5 days for some weird reason. ![]()
Perhaps the problems are specific to 6 GHz?
New Laptop 13 Ryzen Ai 350, Mediatek wifi card, running Fedora 42, having serious wifi issues. I am getting download speeds around 20k/s no matter what I do. My home network is an Asus ZenWifi xt8 mesh with three nodes, and multiple other devices on my network get full bandwidth, around 600M/s. This includes another older laptop sitting right next to this one, also running Fedora 42, so this isnāt a Fedora compatibility issue with my network.
I ran the wifi analysis tool and it told me āYour modern WiFi system is functioning properlyā which is definitely not true.
I did try running wavemon during a download, and the most notable thing is that I am apparently getting thousands of TX retries, if Iām reading this right Iām retrying 63% of TX packets.
Other machines on this network are not having this issue. The Fedora machine sitting next to this had no TX retries.
Iāve updated firmwares, have the latest kernel, all updates installed. Does anyone have any suggestions? Should I be buying another wifi card?
Hi Joe,
Please open a support ticket and link to this thread. Ask to be escalated to the Linux Support Team please (Mention I asked specifically).
I already had a ticket open, I just responded to it with the request to escalate. Thank you.
Hi, I am running Ubuntu 24.04.2 LTS, and my WiFi adapter seems to have just disappeared without warning.
Kernel version is 6.14.0-27 so I guess that is the issue butā¦. how do I patch it?
Simple instruction very welcome ā TIA!
Edit to add: I am on the Ryzen 7040 chipset, possibly I am in the wrong thread.
Edit again: wifi adapter is back after a few restarts⦠for now. I tried using apt update to get the latest kernel but that seems to be what I have, for numbat.
Have you also done apt upgrade after doing the update?
Yes, fair question. I dis upgrade, but what I didnāt do was restart the computer. Will try that tonight
By the way, I was escalated to Linux support, and they suggested sending me an Intel wifi card. Iām open to diagnosing the issue with the AMD card if it can help with stability for others.
I just bought an Framework 13 with AMD, and I am having a freezing issue, but the wifi is fine (Ubuntu 24.04). Could you point me to the correct thread for the freezing issue?
Iām running 25.04 and havenāt experienced any freezing.
If you donāt want to upgrade from 24.04 to 25.04, you could try the mainline kernel package.
