Framework mainboad + Coolermaster BIOS Update - less risky solution
As with everything, do this at your own risk.
If only thing stopping us updating the BIOS on the Mainboard+Coolermaster combo is the lack of a battery just get a battery.
My 11th Gen intel mainboard was stuck on BIOS version 3.17 and 3.20 is available. I am not super savvy when it comes to computery things so most of the solves on this issue were just too risky for me to attempt. I knew I would mess it up somehow.
What I did:
  • Downloaded the BIOS and Driver bundle from Framework
  • Bought a 55wh battery for Laptop 13 from Framework for about $60 total (CHECK COMPATIBILITY - I got the smaller battery because the 61wh battery needed BIOS 3.19 or above on an 11th gen board). I also had the computer hooked up to a UPS.
  • Backed up eeeeverything on my computer
  • Shut down the computer
  • Take the mainbaord out of the case
  • Put it on an anti-static matt.
  • Attach the battery carefully using a plastic shim (I got red blinking lights on the MoBo)
  • Plug in the AC power and an HDMI/USB-C monitor.
  • Use a plastic shim to press the power button on the top right of the mobo.
  • The computer turned on, recognised the battery and I was able to update the BIOS without issue (mostly).
Why I think this is a good solution:
  • While this is not without risk I think it is far easier to mitigate the risk. Use an anti-static matt, keep an eye on the fan, destatic yourself before handling the motherboard.
  • I understand there is extra expense by getting the battery but I would rather spend $60 once and not brick the computer. Then if you ever want to upgrade to a Laptop 13, you already have the battery.
Look out for:
  • When I did this, my fan didn’t power up so I got an external fan and pointed it right at the mobo.
  • Be patient. Just let it do its thing. Don’t touch anything until it has fully restarted and you can confirm that the BIOS has updated in the System information
What I would do differently next time:
  • I didn’t love taking the mobo out of the case. I think I might modify the case to have better access to the connector or find some way to extend the connector so that I only have to take the top of the case rather than lift the whole thing out.
Was this actually a good/smart solution?
I don’t know, lol. For me this made the most sense. My caveman brain said “if no battery is problem then yes bettery is solve problem!” I am very glad it worked but if you are reading this and have any suggestions on how to improve or make this process safer, please get in the comments and let me know!
I hope this helps anyone else who is in my situation!
Happy updating!!
I am replying here with an update. I have completed the process above for the third time without any issue. The only change I made was to leave the mainboard in the case. The battery connected just fine and the fans worked properly.
I’ll be updating the bios this way from now on/until I convert the mainboard into a laptop, lol.
Attached a photo of the setup. It is very easy to do and as long as you take care of any potential static getting at the board you should be fine.
Sorry to necro your post, but this is potentially helpful.
There is actually a process to update w/o a battery installed.
The information can be difficult to find depending on what mainboard you’re using though. Why these details aren’t included in all the BIOS details/instructions via Resources…I don’t know. As far as I can tell essentially all the AMD BIOS versions include the instructions, but it is hit/miss for Intel.
Currently going through a mess replacing a swollen battery and updating bios for my 13 w/ Core Ultra 7 155H. Since information for this specific model seems to be scattered…I eventually stumbled across these details after bouncing around between Resources, Community & Knowledge Base. For w/e reason the newest BIOS for Core Ultra 1 isn’t even listed on Resources page, it is available via Knowledge Base; along with details on how to update w/o a battery.
Your 11th Gen appears to be the only Intel model with these details on the Resources site. It’s called the “standalone” update process. Framework Laptop 13 11th Gen Intel® Core™ — BIOS 3.17 | Resources
