[SOLVED] Update BIOS without BATTERY
Just purchased a couple framework 13 11th gen intel boards and would like to update the bios. Unfortunately it seems to require a battery. How do I override (and assume the risk of power interruption) so I can update the BIOS on these boards?
http://community.frame.work/search?q=BIOS%20update
Welcome to the forum. FYI: The search feature is particularly decent here. A lot of the times you’ll find what you need (when it comes to 11th gen boards, as they’ve been out for 2 years).
Are you in windows or Linux?
tried looking with search and did not find that post. It worked beautifully, thanks! :slight_smile:
