Framework on Ubuntu does not reliably resume from suspension
Dear all,
I have a Framework Laptop 13 AMD with Ubuntu 22.04. Ubuntu is installed on a LUKS encrypted partition. I followed the guide to configure it and update the firmware.
The problem is that sometimes, when the laptop goes in suspension and I open the lid or press the power button to wake it up, it boots from GRUB instead of restoring the previous session.
Did anyone have similar issues? Do you have a solution?
This is probably related to [RESPONDED] Laptop crashes and reboot sometimes after resuming from suspend. I will follow that
