Fair if that’s your view point. Mine is different, AI often brings angles that I consider helpful to look into. It also cuts through noise and is not subject to emotional interpretations.
Back to the topic du jour. Do you have hard evidence to support your claims on DHH? Or just opinion pieces?
People share their perspectives, as you have done, it’s perfectly fine to disagree, but nobody owes you whatever clears your personal bar for “evidence”.
Not to mention, we’ve already discussed this at length in this exact thread, if he cared to actually read through it. But fine MarcoJ, maybe this will clear things up:
I just realized Omarchy isn’t even sponsored by Framework, they literally just tweeted about it a few times. What even is the point of this whole discussion then
“Sponsor” doesn’t just mean “give cash to”. They gave DHH hardware, and they aggressively promoted Omarchy and Hyprland. That’s bad, but Nirav’s response was worse.
Attention is a valuable resource, giving Omarchy positive attention (significantly more than any other distro, scroll up, someone assembled a neat summary) isn’t nothing.
This. Plus Omarchy is the fastest growing Linux Desktop distribution in the past 3 months. This makes even intensive tweeting about it absolutely legit.
I still think Omarchy doesn’t deserve the hype it’s getting right now. But I think given the hype it is getting, tweeting about it (without even mentioning or promoting DHH himself in any way) makes total sense.
For context, I definitely don’t support and don’t agree with DHH’s political views. I just don’t think it’s relevant here. Is the assumption that people will start using Omarchy, then decide to learn about its creator, read his blog and fall into a right wing pipeline? I don’t think that’s a likely scenario.
Are people with fossil fuel powered cars more likely to be climate change deniers? Probably not, but positive coverage of a white-washing campaign by fossil fuel companies is still considered counter productive by people who care about a turn towards green energy.
Well Twitter is owned by a guy who’s much more right wing than DHH, and Framework posting on there directly promotes the platform and brings revenue to the guy. Shouldn’t that be a bigger problem by this logic?
It’s especially praised for allowing for a smooth transition from macOS, it just work out of the box and it looks amazing:
What an interesting point MarcoJ. If I didn’t know any better, I’d swear you’re a paid advertiser for Omarchy. But have you considered this answer to your many irrelevant questions?
There’s many of them in this thread that you’ve willingly ignored, but never the matter. Before I stop engaging with you, I will leave the following memes, which you can use as an exercise to figure out what they mean:
Not really, because they’re (presumably) not sending Framework laptops to Twitter employees; but I believe we’ve already implicitly established that posting on Twitter is quite an unintelligent move
