Framework_tool segmentation fault kubuntu 24.04.2 LTS
A brand new (received and installed the os today) framework 13 laptop running kubuntu 24.04.2 lts.
I can install and build a partially working framework_tool
sudo ./target/debug/framework_tool --info
[sudo] password for ul:
Summary
  Is Framework: true
  Platform:     IntelCoreUltra1
BIOS Information
  Vendor:       INSYDE Corp.
  Version:      03.04
  Release Date: 10/09/2024
System Information
  Version:      Some(MassProduction) (A2)
  Manufacturer: Framework
  Product Name: Laptop 13 (Intel Core Ultra Series 1)
  Wake-Up-Type: PowerSwitch
  SKU Number:   FRANDJCP02
  Serial Number:<redacted>
  Family:       Laptop
BaseBoard Information
  Product:      FRANMECP02
System Chassis Information
  Type:         Notebook
but I’m getting seg faults for most options. For example:
sudo ./target/debug/framework_tool --charge-limit
Segmentation fault
(charge limit is currently set to 60% via bios)
Is this a good question for the forums (if so where?) or should I post on framework-system github issues?
EDIT I managed to get the following back trace:
sudo rust-gdb --args ./target/debug/framework_tool --charge-limit
(gdb) r
Starting program: /home/ul/tmp/framework-system/target/debug/framework_tool --charge-limit
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libcap.so.2
Program received signal SIGSEGV, Segmentation fault.
0x00005555556807f3 in hwio::pio::{impl#2}::write (self=0x7fffffff9a52, value=288)
    at /home/ul/.cargo/git/checkouts/rust-hwio-1ba602c57f8be0b1/9bcff42/src/pio.rs:228
228                 asm!("out dx, ax", in("ax") value, in("dx") self.port, options(nostack));
(gdb) bt
#0  0x00005555556807f3 in hwio::pio::{impl#2}::write (self=0x7fffffff9a52, value=288)
#1  framework_lib::chromium_ec::portio_mec::transfer_read (address=288, size=2)
    at framework_lib/src/chromium_ec/portio_mec.rs:173
#2  0x0000555555664f99 in framework_lib::chromium_ec::portio::init ()
    at framework_lib/src/chromium_ec/portio.rs:95
#3  0x000055555566693f in framework_lib::chromium_ec::portio::send_command (
    command=15875, command_version=0, data=&[u8](size=3) = {...})
    at framework_lib/src/chromium_ec/portio.rs:242
#4  0x00005555556acecd in framework_lib::chromium_ec::{impl#2}::send_command (
    self=0x7fffffffb7ed, command=15875, command_version=0, data=&[u8](size=3) = {...})
    at framework_lib/src/chromium_ec/mod.rs:1457
#5  0x00005555555fffe0 in framework_lib::chromium_ec::command::EcRequestRaw::send_command_vec_extra<framework_lib::chromium_ec::commands::EcRequestChargeLimitControl, framework_lib::chromium_ec::commands::EcResponseChargeLimitControl> (self=0x555555aeb97e,
    ec=0x7fffffffb7ed, extra_data=&[u8](size=0))
    at framework_lib/src/chromium_ec/command.rs:156
#6  0x000055555561a1cc in framework_lib::chromium_ec::command::EcRequestRaw::send_command_extra<framework_lib::chromium_ec::commands::EcRequestChargeLimitControl, framework_lib::chromium_ec::commands::EcResponseChargeLimitControl> (self=0x555555aeb97e,
    at framework_lib/src/chromium_ec/command.rs:178
#7  0x00005555556159e5 in framework_lib::chromium_ec::command::EcRequestRaw::send_command<framework_lib::chromium_ec::commands::EcRequestChargeLimitControl, framework_lib::chromium_ec::commands::EcResponseChargeLimitControl> (self=0x555555aeb97e, ec=0x7fffffffb7ed)
    at framework_lib/src/chromium_ec/command.rs:170
#8  0x000055555569febe in framework_lib::chromium_ec::CrosEc::get_charge_limit (
    self=0x7fffffffb7ed) at framework_lib/src/chromium_ec/mod.rs:428
#9  0x00005555555d6e78 in framework_lib::commandline::handle_charge_limit (
    ec=0x7fffffffb7ed, maybe_limit=...) at framework_lib/src/commandline/mod.rs:1489
#10 0x00005555555cd954 in framework_lib::commandline::run_with_args (
    args=0x7fffffffdc78, _allupdate=false) at framework_lib/src/commandline/mod.rs:817
#11 0x00005555555c4f83 in framework_tool::main () at framework_tool/src/main.rs:40
Reported and resolved (at least for me) here.
kubuntu 24.04.2 lts use v6.11 kernels. The framework_tool needs >=v6.12 kernels or an appropriately patched cros_ec_lpc 6.11 lkm to function.
Apparently, 24.04 lts is scheduled to get kernel 6.14 in August with the 24.04.2 → 24.04.3 update so best wait for that or go through the pain of compiling a patched cros_ec_lpc, DKMS compliant, 6.11 loadable kernel module (and then undoing that when the kernel updates to 6.14).
