Frequent Freezes and Initramfs Error on Ubuntu 24.10
I’ve been experiencing some frustrating issues with my Ubuntu 24.10 installation.
My OS after suspend frequently freezes, and when I hard restart my device, I encounter an initramfs error. After restarting again, the error goes away.
I’ve done some searches about this problem and reviewed my logs (attached below).
2024-11-15T22:28:03.135904+01:00 framework systemd-sleep[39340]: Failed to freeze unit 'user.slice': Connection timed out
2024-11-15T22:28:03.147102+01:00 framework systemd-sleep[39340]: Performing sleep operation 'suspend'...
2024-11-15T22:27:35.079924+01:00 framework kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
from what I have read, it could be related to systemd v256.
But not sure how to confirm or what to do to fix this issue
Any guys with a similar syndrome?
Guillaume
ubuntu-24.10
kernel: 6.11.0-9-generic
bios: 3.05
framework model: AMD Ryzen™ 7040 Series - FW13 7640U
systemd 256 (256.5-2ubuntu3)
I can’t help you with the hibernation part, as I never use it because I use encrypted filesystem requiring me to enter the password anyway.
I configure the system to use session management, and shutdown.
the boot process is so fast under linux, I don’t really care shutting down. If I make a pause, I just put it to sleep.
Hibernation, IMHO, as it write the RAM content to disk, is just a way of wearing the SSD prematurily.
I’m experiencing the same. Sometimes a freeze with a forced reboot. Then the initramfs prompt and after another reboot the system is back up.
I do use an encrypted filesystem, maybe disabling hibernation is way to fix this?
My versions match yours exactly. I try to keep my system as up to date as possible.
I have a workaround that you may try. based on https://www.reddit.com/r/archlinux/comments/1djowpp/comment/l9hed36/
create these 2 files
/etc/systemd/system/systemd-homed.service.d/override.conf
/etc/systemd/system/systemd-suspend.service.d/override.conf
with this content
in /etc/systemd/system/systemd-homed.service.d/override.conf
[Service]
Environment="SYSTEMD_HOME_LOCK_FREEZE_SESSION=false"
in /etc/systemd/system/systemd-suspend.service.d/override.conf
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
and then
sudo systemctl daemon-reload or reboot
Is this still working for everyone? I can’t seem to get it to work…
It sounds like a SSD firmware bug to me. What make, model and firmware version is the ssd.
I am using Samsung’s 990 Evo (1TB) as I’ve had good results with them in the past.
I am using Sandisk 500 GB.
No issues anymore since I applied Frequent Freezes and Initramfs Error on Ubuntu 24.10 - #4 by ramelet_guillaume
After opening up my laptop and reseating the eDP cable on both ends and my SSD as well the issue has entirely disappeared.
I’ve added the code you suggested after yet another initramfs error after resuming my system from sleep. :slightly_frowning_face:
Will report back if this fixes the issue for me. It happens 1/10 times so it’s a bit difficult to properly test this fix.
Last update: it happend twice in the last week. :grimacing: The code change in the systemd didn’t fix it for me.
I’m seriously considering downgrading to Ubuntu 24.04, though I wonder if it faces the same issues…
