Recently changed mainboard and now suspend-then-hibernate no longer works
Ubuntu
Which release version?
24.04.2 LTS
Which kernel are you using?
3.05
AMD Ryzen 5 7640U
I recently had my Intel 12th gen mainboard die and replaced it with a 7640U mainboard. Since replacing the mainboard suspend to hibernate no longer works. Looking at the logs I see this:
May 12 22:02:07 Framework systemd-sleep[20996]: System returned from sleep operation 'suspend-then-hibernate'.
May 12 22:02:07 Framework systemd[1]: anacron.service - Run anacron jobs was skipped because of an unmet condition check (ConditionACPower=true).
May 12 22:02:07 Framework systemd[1]: Starting fwupd-refresh.service - Refresh fwupd metadata and update motd...
May 12 22:02:07 Framework systemd-sleep[20996]: BAT1: Failed to update battery discharge rate, ignoring: Numerical result out of range
May 12 22:02:07 Framework systemd[1]: Starting sysstat-collect.service - system activity accounting tool...
May 12 22:02:07 Framework systemd[1]: sysstat-collect.service: Deactivated successfully.
May 12 22:02:07 Framework systemd[1]: Finished sysstat-collect.service - system activity accounting tool.
May 12 22:02:07 Framework systemd-sleep[20996]: Failed to write mode to /sys/power/disk: Operation not permitted
May 12 22:02:07 Framework systemd-sleep[20996]: Couldn't hibernate, will try to suspend again.
May 12 22:02:07 Framework systemd-sleep[20996]: Performing sleep operation 'suspend'...
May 12 22:02:07 Framework kernel: PM: suspend entry (s2idle)
May 12 22:02:07 Framework kernel: Filesystems sync: 0.005 seconds
Any ideas on how to fix this?
EDIT
I figured it out. I needed to disable Secure Boot on the new mainboard.
