From 25.10 Kubuntu to neon, fedora, or other KDE plasma?
I have AMD Ryzen AI 7 laptop, and enjoyed Kubuntu as my first Linux (even before framework).
I’ve discovered that my favorite thing with Linux is KDE plasma, and I’d like to get updates more often. I looked at KDE neon but description makes me think that it might require more troubleshooting than I’d like.
is fedora then next good choice for frequent KDE plasma updates? I’ve also heard of other distributions that use it, but definitely appreciate popular distros since it’s easier to troubleshoot.
if there’s a KDE plasma distro you enjoy, let me know! I’d like to try it, and see which one sticks.
Fedoras Plasma edition is propably the best if you want to have “up to date” system.
Arch and its “spins” are another option but that will require interventions at some point when packages are updated / split etc.
If atomic distros are not out of the question (this atleast doesn’t require manual upkeep) then there is Bazzite and Aurora which are KDE based (Bazzite also has a gnome edition).
Thank you I’ll check aurora out! Also heard of opensuse but might skip since might be too niche for newbie
Update: KDE Fedora is rock stable, learning curve was small (no more .deb installs!), and i already have later KDE than with kubuntu!
