FW12 Aggressive Battery Drain with Lid Closed Ubuntu
Which Framework Laptop 12 model are you using? (13th Gen Intel® Core™) (Isn’t this the only one?)
Lasts like 3h with lid closed. Feels warm to the touch, even with battery charged and white LED status.
Any ideas how to stop this? I want a functional laptop, and this isn’t functional in this state. It should drain a couple percent, not ~30%/hr
Is the LED solid white, or slowly flashing?
when lid closed, slowly flashing, more like pulsing.
I realized it wasn’t clear if you were referring to the charger LED or the power button LED. But power button LED pulsing means it should be properly suspended… What version of Ubuntu? I’m running Fedora 43 and my FW12 suspends properly with little power draw.
That sounds like it isn’t properly suspending to RAM on lid close.
Try going to the /etc/systemd/logind.conf file that has
#HandleLidSwitch=suspend
#HandleLidSwitchExternalPower=suspend
and make sure that’s how the settings are.
I also had some problems with keypressed while the lid is closed waking up the computer. Is that what’s going on?
Fully up to date LTS
/etc/systemd/logind.conf says
But doesn’t # mean comment, so it’s not in effect?
I don’t think so. The light is pulsing like it’s suspending fine.
What kernel version? Are you running the HWE kernel? Framework recommends 6.13 or later for the FW12.
6.14.0-35-generic
Everyone else is having good battery drain with the lid closed?
In my case it wasn’t that bad, but still quicker than I expected, while investigating some freezes I came across the type of idle - s2idle vs deep - s2idle is the default and it doesn’t shut off the memory. Perhaps it’s related to the memory you are using?
I wrote some more details here at the time: Laptop12 w/ KUbuntu 25.04 freezing when suspending - #6 by Guido_Vezzoni
I had this issue (Ubuntu with Xfce). Fixed it by changing the lid-down behavior in the power settings to “suspend”.
I think this works, though it’s sad to not use the normal state that others are using successfully s2idle). Thank you.
As you can see in this very thread, it’s already set to suspend.
