FW16 USB PD Battery Issues
I think what’s happening is that when the power bank detects the cable is EPR enabled, outputting fixed power of 140W, the Framework 16 Embedded Controller ( part of the BIOS ) is trying to negotiate with the power bank using EPR + AVS, but it fails because the power bank ( output only ) doesn’t support AVS, and the FW16 retries after some delay ( I think approximately 1 seconds ) repeatedly until you unplug the power bank
Interestingly, I tested the PD protocol support with my 2 devices mentioned above, of which one works with 140W. Here are the results:
Powerbank (works with 140W):
Fixed: 5V 3A
Fixed: 9V 3A
Fixed: 12V 3A
Fixed: 15V 3A
Fixed: 20V 5A
PPS: 4.50-21.00V 5A
EPR Capable
Fixed: 28V 5A
Charger (does NOT work with 140W):
Fixed: 5V 3A
Fixed: 9V 3A
Fixed: 15V 3A
Fixed: 20V 5A
PPS: 5.00-11.00V 5A
EPR Capable
Fixed: 28V 5A
AVS: 15-28V
I’ve highlighted the differences. So, based on the results of this USB-C tester (Power-Z KM003C), the device which supports AVS is the one that does not work properly, while the device which only supports EPR with fixed voltage 28V, does charge it at high wattage.
So I’m not sure if the results are similar with a different power bank, and I can’t be 100% confident of these test results, but from these, it looks like the AVS would likely be the problem, as it works with the powerbank which does not support AVS but only supports 28V fixed voltage with max 5A.
As for the mentioned concern - how the laptop could charge with fixed setting in case the battery is already full - that should not be a problem, as only the voltage part in the protocol is fixed. Current is still being drawn only as much as needed/supported. Once the laptop is charged, it would either limit the current (amps) drawn at the same voltage, or possibly renegotiate to a lower voltage. With proper support for AVS, the device can constantly tune the voltage as well, in small increments, to provide the maximum efficiency or charging speed.
Therefore, I assume there is something wrong with the negotiation when using AVS. However, I’m unable to confidently say if this is on the side of Framework or the side of Anker charger (140W port), because I don’t have another AVS capable sink device to test on - the power bank charges at 140W, but also seems to use fixed voltage for charging.
Hi I ran into similar issue and wanted to mention it.
I have alza power APW-HCA82SLY USB-C replicator.
If i connect framework charged to its USB-C connector, laptop will become wery slow, and there are similar messages in dmesg:
[ 1074.236464] workqueue: ucsi_handle_connector_change [typec_ucsi] hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
[ 1078.436648] workqueue: ucsi_handle_connector_change [typec_ucsi] hogged CPU for >10000us 8 times, consider switching to WQ_UNBOUND
[ 1087.466008] workqueue: ucsi_handle_connector_change [typec_ucsi] hogged CPU for >10000us 16 times, consider switching to WQ_UNBOUND
[ 1101.003594] workqueue: acpi_os_execute_deferred hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
[ 1104.849760] workqueue: ucsi_handle_connector_change [typec_ucsi] hogged CPU for >10000us 32 times, consider switching to WQ_UNBOUND
[ 1115.328705] usb 7-1: USB disconnect, device number 2
[ 1115.328770] usb 7-1.5: USB disconnect, device number 3
[ 1115.354820] usb 8-1: USB disconnect, device number 2
[ 1115.354954] usb 8-1.1: USB disconnect, device number 3
[ 1115.359265] cdc_ncm 8-1.1:2.0 enxa0cec8acd065: unregister 'cdc_ncm' usb-0000:c3:00.3-1.1, CDC NCM (NO ZLP)
[ 1115.390886] usb 8-1.4: USB disconnect, device number 4
[ 1115.934868] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-70)
[ 1116.445178] workqueue: acpi_ec_event_processor hogged CPU for >10000us 8 times, consider switching to WQ_UNBOUND
and secont try
[ 1216.409648] workqueue: power_supply_changed_work hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
[ 1236.034202] workqueue: ucsi_handle_connector_change [typec_ucsi] hogged CPU for >10000us 64 times, consider switching to WQ_UNBOUND
[ 1243.184519] usb 7-1: USB disconnect, device number 4
[ 1243.184589] usb 7-1.5: USB disconnect, device number 5
[ 1243.217186] usb 8-1: USB disconnect, device number 5
[ 1243.217354] usb 8-1.1: USB disconnect, device number 6
[ 1243.230612] cdc_ncm 8-1.1:2.0 enxa0cec8acd065: unregister 'cdc_ncm' usb-0000:c3:00.3-1.1, CDC NCM (NO ZLP)
[ 1243.358312] usb 8-1.4: USB disconnect, device number 7
[ 1243.819133] ucsi_acpi USBC000:00: unknown error 0
[ 1243.819149] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
I had similar behavior with some noname USB-C replicator that i borrowed.
can you report what sensors report?
> sensors
ucsi_source_psy_USBC000:004-isa-0000
Adapter: ISA adapter
Voltage   Back Left:   0.00 V  (min =  +0.00 V, max =  +0.00 V)
Current:               0.00 A  (max =  +0.00 A)
ucsi_source_psy_USBC000:003-isa-0000
Voltage Middle Left:   0.00 V  (min =  +0.00 V, max =  +0.00 V)
Current:             680.00 mA (max =  +0.00 A)
ucsi_source_psy_USBC000:001-isa-0000
Voltage   Back Right:  20.00 V  (min =  +5.00 V, max = +39.00 V)
Current:                5.00 A  (max =  +6.12 A)
ucsi_source_psy_USBC000:002-isa-0000
Voltage Middle Right:   5.00 V  (min =  +5.00 V, max =  +5.00 V)
Current:                0.00 A  (max =  +1.50 A)
in this case the “Back Right” is connected to a 100W power (Chargeur Anker Prime (250 W, 6 ports, GaNPrime) - Anker FR)
But with this power when I use a 140W port it do not report Voltage and do not work correctly for me…
When I plug my FW charger to right back port with battery at 87% (charging stops at 90%)
mt7921_phy0-pci-0100
Adapter: PCI adapter
temp1:        +32.0°C
in0:           0.00 V  (min =  +0.00 V, max =  +0.00 V)
curr1:         0.00 A  (max =  +0.00 A)
in0:           5.00 V  (min =  +5.00 V, max =  +5.00 V)
curr1:         0.00 A  (max =  +1.50 A)
nvme-pci-0200
Composite:    +28.9°C  (low  = -40.1°C, high = +83.8°C)
                       (crit = +87.8°C)
Sensor 1:     +40.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 2:     +28.9°C  (low  = -273.1°C, high = +65261.8°C)
amdgpu-pci-c100
vddgfx:        1.30 V
vddnb:       672.00 mV
edge:         +30.0°C
PPT:          12.25 W  (avg =   5.21 W)
k10temp-pci-00c3
Tctl:         +33.1°C
curr1:         5.00 A  (max =  +3.00 A)
BAT1-acpi-0
Adapter: ACPI interface
in0:          17.35 V
curr1:       231.00 mA
when i plug my FW charger through my expander to right back port (battery at the same SOC)
temp1:        +34.0°C
nvme-pci-0200
Composite:    +29.9°C  (low  = -40.1°C, high = +83.8°C)
                       (crit = +87.8°C)
Sensor 2:     +29.9°C  (low  = -273.1°C, high = +65261.8°C)
amdgpu-pci-c100
vddgfx:      715.00 mV
vddnb:       669.00 mV
edge:         +31.0°C
PPT:           4.18 W  (avg =   4.14 W)
k10temp-pci-00c3
Tctl:         +33.5°C
in0:          20.00 V  (min =  +5.00 V, max =  +5.00 V)
curr1:         3.75 A  (max =  +0.10 A)
BAT1-acpi-0
in0:          17.02 V
curr1:       605.00 mA
look to be the right back port…
so we get:
#>  100W Power charger
#> FW 180W charger ?
#> alza power APW-HCA82SLY USB-C replicator.
# on a 65W charger I get:
Voltage   Back Right:  20.00 V  (min =  +5.00 V, max = +38.80 V)
Current:                5.00 A  (max =  +3.56 A)
Look rely there is something bad somewhere … (linux sensors report / EC report / PD negociation…)
Did some on know if we can get PD config/stat from EC ? (with ectool tools?)
I too have the Anker Prime, never had an issue.
My FW 16 loads at 140 W when the battery is empty (actually the powerbank reports 139 and sth. watts).
I always used the cable that came with the powerbank, never tried a different one.
A bit heavy, this powerbank, but otherwise does what it should well, recommended.
BTW the power bank also recharges super fast with the Framework 180 W power adapter - amazing!
Hi, I just udate bios to 3.5 and my issues with seem to be resolved.
So, I’ve been eyeing the Anker 140W power banks, and a few other 140W power banks, but mostly the Anker ones. I’ve been wanting a high output power bank to charge my laptop while I game on the plane while I travel. I just reviewed all the posts here and from what I can tell from these posts anyone with the Anker 737 140W seems to have an issue charging the FW16 at 140W, and people with the Anker Prime 140W don’t have an issue charging FW16 at ~140W.
Should I avoid the 737 and go with the Prime?
I think the problem is when both ends of the USB-C link are “Dual role”.
It becomes a guess as to which should charge the other.
If you can find a power bank that has one USB-C port for charge source, and a different USB-C port for charge sink, you will be OK, because then both sides are not “Dual role sink/source”
I have tested a lot of powerbanks with the 13 and most of them have a single usb-c port for charge and discharge which all negotiated fine (after that one bios update that fixed sub 65w pd charger support). Still having a bios or ectool or whatever toggle that turns the port sink or source only would probably be quite useful to at least temporarily cover edge cases.
I have the 737 - doubletap the power button (makes it go into trickle charge mode, shown by a green dot on the top left of the display) and it will charge the FW16 just fine.
It just does not in the default mode, for whatever reason.
Good to know. That probably also works similarly on the Prime. I’ve been wanting something that will output more than 100W (although 60W or more would probably be ok). I’ve been using the Anker Nano that I’ve had for my phone on my flights. 22.5W is better than nothing but I have to make sure I plug it in at the beginning of the flight otherwise my FW16’s battery drains, and the Nano still has charge. It just doesn’t transfer the power fast enough. I drain my laptop and the Nano before I have to put up my laptop. :frowning:
