FWRK13AMD resets abruptly and fails to find a bootable device
Not sure if related to my OS at all, but this is what I have:
$ nixos-version
24.05.20241006.ecbc1ca (Uakari)
$ uname -rv
6.6.52 #1-NixOS SMP PREEMPT_DYNAMIC Wed Sep 18 17:24:10 UTC 2024
$ sudo dmidecode -s bios-version
03.05
$ sudo dmidecode -s system-product-name
Laptop 13 (AMD Ryzen 7040Series)
I am working as usual, and then suddenly my external screen (with USB-C PD) goes black. I disconnect the screen, open the laptop lid, and see the firmware complaining that it cannot find a boot device. But the OS was booted, and if I restart again, the OS boots fine.
I’ve had this machine waking up from sleep, and either running out of battery, or overheating (in backpack), but this is different. I am interested in what the RCA can be for the reset, as well as for the undetected NVMe boot device. A bad contact somewhere? Voltage drop? No idea?
Unable to reproduce. Has anyone ever experienced such a thing?
did you check the uefi table?
smurphy@jupiter:~$ efibootmgr
BootCurrent: 0003
Timeout: 3 seconds
BootOrder: 0003,0000,2001,2002,2003
Boot0000* EFI Hard Drive (48797879300891-Sabrent SB-2130-1TB)   PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/NVMe(0x1,64-79-A7-79-DA-30-11-E1)/HD(3,GPT,5258e526-a9fb-dc49-8875-fcf04bf2e378,0x800,0x100000)RC
Boot0002* EFI PXE 0 for IPv4 (0C-37-96-80-1C-7E)        PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x3)/USB(6,0)/USB(2,0)/MAC(0c3796801c7e,0)/IPv4(0.0.0.00.0.0.0,0,0)RC
Boot0003* Neon  HD(3,GPT,5258e526-a9fb-dc49-8875-fcf04bf2e378,0x800,0x100000)/File(\EFI\neon\shimx64.efi)
Boot2001* EFI USB Device        RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network   RC
$ efibootmgr
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0000,2001,2002,2003,0001
Boot0000* EFI Hard Drive (23250Z801034-WD_BLACK SN850X 2000GB)  PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/NVMe(0x1,00-1B-44-8B-4A-E4-76-B6)/HD(2,GPT,931a861a-b7d7-45a3-b91d-b3e7ea1a76ec,0x1c1c1100,0x20000)RC
Boot0001* Linux Boot Manager    HD(2,GPT,931a861a-b7d7-45a3-b91d-b3e7ea1a76ec,0xe0e08800,0x100000)/File(\EFI\systemd\systemd-bootx64.efi)
Boot0003* Windows Boot Manager  HD(2,GPT,26bedf9f-4b32-435d-98fb-4e9e25ce2800,0xa00800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000048000100000010000000040000007fff0400
Boot0004* Windows Boot Manager  HD(2,GPT,26bedf9f-4b32-435d-98fb-4e9e25ce2800,0xa00800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000048000100000010000000040000007fff0400
…is any of that wrong? Sure, I might need to change the order to avoid the removable devices, so 0000,0001,everything-else, but in principle, why would this cause any issue? Especially reseting a running OS with uptime of many days, and then, after this issue, booting perfectly fine again after cold restart.
Looks good. But he takes the first boot device for booting (0000), so looks on the disk itself.
So whatever is installed on partition 2 on the SN850X will be booted. On my setup, this is the partition holding the EFI files.
So if all EFI files are correct/not faulty, it should work.
There was another issue similar to yours. This is the link to it: Rebooting/restarting from OS fails, but shutting down and turning on works
This one is for the Framework 16 though.
Can you try updating your BIOS to a newer version to see if the issue still occurs? Try updating from 6.6 to something 6.8+.
