Getting triple surround to work with Laptop Display and dgpu
Hey there! Has anyone been able to successfully get the framework 16 to work with surround (AMD eyefinity i believe) such that the Framework 16 laptop display can be used as the middle screen? I have two portable monitors that I connect to the dgpu using an mst hub. In the Adrenaline software I can see both monitors are displayed to by the dgpu. The issue is that I can’t get the Framework 16 display to be connected to the dgpu directly to set up the surround settings.
I’m able to get the two portable monitors to connect to each other in surround but the laptop display is controlled by the igpu still. One thing I tried is booting up a game to switch the mux so that the laptop display is controlled by the dgpu but it doesn’t appear to be switchable when an external monitor is connected to the dgpu.
Is it possible to force the mux to have the dgpu control the monitor at all times? Is there a limitation in the system that prevents the laptop display being controlled by the dgpu when an external monitor is connected to it?
