I did just confirm that I do have that issue.
Did you build the patched kernel from source?
Yes, following these instructions:
I figured as much
I did that a while back to test a d3cold issue.
Since mine is only messing up when booting from battery, Ill wait ![]()
Currently installing a single node openshift environment and don’t feel like messing w/the kernel today lol
Throwing my hat in the ring since this issue literally just happened to me.
System
Strangely, I’ve mostly had this problem when waking from sleep, but this time was different. I was gaming on battery using the 7700S (MangoHud showed it as active) and when I closed the lid after plugging in my monitor, the dGPU disappeared from Mission Center. FastFetch shows the dGPU though.
I’m still fairly new to Linux troubleshooting, so I’d be happy to help if guided.
So since the following update the graphics card seems to be active for some time now, I have nvtop open all the time and even after the supsend it is still active.
fedora:fedora/42/x86_64/silverblue
Version: 42.20250417.0 (2025-04-17T17:29:03Z)
BaseCommit: b6784a601685fd9f89e667f29676f6a6da9c7721becc921b5239a77f4331b196
nvtop keeps the gpu awake and will prevent it from sleeping
Yes, the problem is rather that the graphics card would have to be usable first and I only have that at every hundredth start or even less often ![]()
Ah. Yeah, I haven’t had the courage to update my Fedora yet, which is a real shame.
That there is no way to hard wake up the graphics card, but I haven’t found anything yet. A console command would be enough for me.
I had the same problem on Fedora 41/42. Installing Kernel 6.12 from this COPR solved the problem for me. I had to disable Secure-Boot as well to boot this kernel.
Reliable with sleep and multiple reboots?
I have tried all the kernels listed here and none of them could reliably run the graphics card.
Not sure what you mean with multiple reboots, but yes, it wakes up fast and reliable from sleep (so far).
That the graphics card is also available every time the notebook is started.
Shortly after a kernel update it often works after 1-4 starts, but then it is always gone for me.
Seems very stable to me. I had no issues after reboots or waking from suspends after installing the LTS Kernel on Fedora 42, even when switching from docked to undocked while asleep.
This happened to me recently. I hadn’t updated or even rebooted in a bit, but one day the 7700S no longer appears. Using older or recent versions of linux kernels 6.6, 6.12, and 6.14 make no difference. Checked with a USB drive with Arch LInux and Windows and neither could see the dGPU either.
Given the issue in this thread is a driver level issue and two of the kernels and one of the OSes listed do not exhibit the particular driver bug, I’d recommend opening a support ticket. if the dGPU is not appearing in windows device manager nor linux lspci commands, then something different is happening, and the support team would be equipped to help you troubleshoot and to handle warranty replacement of parts should that be necessary and applicable.
This being a community forum the support team does not actively monitor it, so opening a ticket is the correct way to get their attention.
I finally worked up the courage to update to Fedora 42 last night. I was incredibly surprised, and pleased, to find that my graphics card worked (kernel 6.14.5)! I don’t know if it’s 100% reliable, I only did just a little testing, but it did at least work on that boot
i didn’t dare to update anymore, would you like to confirm again when you have tested it for a few days/restarts?
Yeah, I’ll report back either once I have an issue, or sometime next week if I haven’t had an issue. If I do run into an issue, I see my 6.13.5 kernel is still there, so I should be able to boot using that and still hack my way through.
You can pin a deployment so that it never gets cleaned up, that’s what I currently do with a version that works.
sudo ostree admin pin 0
0 is the first to be displayed for the status
rpm-ostree status
The command to pick up the pin is a little strange
sudo ostree admin pin --unpin 0
