I got my FW 16 a couple weeks ago and today wanted to use it to connect to my workstation’s displays. I was trying to connect the graphics module through a USB C to DP adapter to my monitor, but it doesn’t show any picture. Plugging the display into one of the side USB Cs works, but of course outputs the image through the internal GPU.
EDIT: I just noticed the RX 7700S graphics module isn’t shown in the device manager or in the AMD Software. Is it broken?
EDIT2: I removed the graphics module and reinstalled it, somehow that seems to have fixed it. I can now output display through the GPU. However, if I try to connect a second display through a side USB C port, that doesn’t seem to work. It should be possible in principle though right?
