[Guide] Getting Nvidia Optimus working on Arch/Hyprland
it took me a while to get this running in a satisfactory way, so i wanted to add all the steps i took to get this working. im using hyprland, and your environment variables for starting the desktop environment may look different but this is what works for me.
during this entire process, you can use nvidia-smi command to see if anything is running on the gpu
im using the nvidia-open driver but this should work on just the nvidia driver too. im also using cachyos but this will also work without modification on arch. you may need to adjust for other distributions.
you will need to have the bios graphics mode set to “hybrid”
add amdgpu before any nvidia thing in the modules in /etc/mkinitcpio.conf
MODULES=(amdgpu nvidia nvidia_modeset nvidia_uvm nvidia_drm)
add kernel parameter for modeset (for systemd-boot it’s at /boot/loader/entries/(your default).conf under options) -
nvidia_drm.modeset=1
rebuild kernel-
sudo mkinitcpio -P
find what your card is assigned to:
ls -l /dev/dri/by-path
my output looks like this:
~ >>> ls -l /dev/dri/by-path
total 0
lrwxrwxrwx 1 root root 8 Jan 9 18:25 pci-0000:c2:00.0-card → ../card0
lrwxrwxrwx 1 root root 13 Jan 9 18:25 pci-0000:c2:00.0-render → ../renderD129
lrwxrwxrwx 1 root root 8 Jan 9 18:25 pci-0000:c3:00.0-card → ../card1
lrwxrwxrwx 1 root root 13 Jan 9 18:25 pci-0000:c3:00.0-render → ../renderD128
i want to find which card is which, so the resulting grep looks like this:
~ >>> lspci -nn | grep -E ‘c2:00.0|c3:00.0’
c2:00.0 VGA compatible controller [0300]: NVIDIA Corporation GB206M [GeForce RTX 5070 Max-Q / Mobile] [10de:2d58] (rev a1)
c3:00.0 Display controller [0380]: Advanced Micro Devices, Inc. [AMD/ATI] Strix [Radeon 880M / 890M] [1002:150e] (rev c1)
it looks like c2 is nvidia and c3 is amd, so based on the previous output, it looks like the amd card is set to card1 and nvidia is set to card0
in hyprland.conf im manually setting which card runs the desktop. the first listed is the desktop card, second is secondary:
env = AQ_DRM_DEVICES,/dev/dri/card1:/dev/dri/card0
setting up more environment variables to make sure anything launches does it with the amd card normally:
env = LIBVA_DRIVER_NAME,radeonsi
env = mesa_glthread,true
env = __GLX_VENDOR_LIBRARY_NAME,mesa
make sure the nvidia card can actually power down with udev rules. i have this in /etc/udev/rules.d/80-nvidia-pm.rules -
#Enable runtime PM for NVIDIA VGA/3D controller devices on driver bind
ACTION==“bind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030000”, TEST==“power/control”, ATTR{power/control}=“auto”
ACTION==“bind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030200”, TEST==“power/control”, ATTR{power/control}=“auto”
#Disable runtime PM for NVIDIA VGA/3D controller devices on driver unbind
ACTION==“unbind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030000”, TEST==“power/control”, ATTR{power/control}=“on”
ACTION==“unbind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030200”, TEST==“power/control”, ATTR{power/control}=“on”
#Enable runtime PM for NVIDIA VGA/3D controller devices on adding device
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030000”, TEST==“power/control”, ATTR{power/control}=“auto”
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030200”, TEST==“power/control”, ATTR{power/control}=“auto”
#Enable runtime PM for NVIDIA Audio devices
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x040300”, TEST==“power/control”, ATTR{power/control}=“auto”
#Enable runtime PM for NVIDIA USB xHCI
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x0c0330”, TEST==“power/control”, ATTR{power/control}=“auto”
#Enable runtime PM for NVIDIA USB Type-C UCSI (Power Delivery)
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x0c8000”, TEST==“power/control”, ATTR{power/control}=“auto”
i also have enabled a service that allows it to smoothly resume -
sudo systemctl enable --now nvidia-persistenced
you should be able to run anything on the nvidia card with prime-run and then nothing you don’t want (ideally.) you can edit .desktop files to make sure stuff like blender or games that aren’t steam launch via the nvidia card.
if nvidia-smi shows no processes, running this should give you a line that says D0 and a line that says D3cold:
cat /sys/class/drm/card*/device/power_state
if you get that output with nothing running on nvidia, you’ve succeeded.
if you use steam-
steam always puts the web helper on nvidia which will spin the card up, i like having steam on in the background. to resolve this you need to launch steam without the ability to see the nvidia card. add this to your autolaunch in hyprland.conf and/or your .desktop file -
for desktop file:
Exec=env VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.x86_64.json /usr/bin/steam %U
in hyprland.conf:
exec-once = VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.x86_64.json steam
after you add this - prime-run won’t work and you have to manually specify the vulkan ICD filename. i did this by creating an executable at /usr/bin/nvidia-run with this content:
#!/bin/bash
export __NV_PRIME_RENDER_OFFLOAD=1
export __GLX_VENDOR_LIBRARY_NAME=nvidia
export VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json
exec “$@”
make it executable:
sudo chmod +x /usr/bin/nvidia-run
and then to run a game on steam with the nvidia card, use the launch options:
nvidia-run %command%
this makes my computer very quiet most of the time and sip power when i don’t need it. im fond of this setup.
