Hibernation does not work anymore after latest BIOS and driver updates
“Windows failed to resume from hibernate with error status 0xC0000001”
The above error is what shows up in event viewer. My FW Desktop fails most of the time to turn on from hibernation.
I know there are a lot of BIOS issues reported with the latest version. Wondering if that or the latest drivers messed it up, as I installed both at the same time.
Anyone else facing this hibernation issue?
Are you using bios 3.04? Try 3.03 I hear 3.04 can cause issues for some folks.
Yes, I actually went back to BIOS 3.03 because support asked me to try that for the slow boot issue, which many others are reporting too. My boot time got back to around 20 seconds. Now I’m curious to see if the hibernation issue is getting fixed by this too. Will report back. Framework Desktop Ryzen AI MAX 300 BIOS 3.04 Release STABLE - #64 by k_peter_06
