My amd framework 13 was making clicking sounds from the upper right corner when opening the laptop and a louder pop sound from the left corner when reaching 70 degrees. It didnt get any better when testing with a removed bezel or more loose / tight hinge screws.
after wasting an hour trying to fix it in various ways i found these two threads:
Hinge clicks - #13 by mjnz
Reddit - Dive into anything
the 2 cables that run from the monitor to the chassis (i think its the display and the antenna cables) have some kind of sticky insulation. when closing the laptop they move in a way that make them stick to the surface behind them, resulting in a click sound when being moved back.
after putting tape around both cables sticky areas the clicking has become somewhat more silent, but i still have no clue how to get rid of it entirely.
please help
