hipEngine: Fast Native Qwen 3.6 Inference for RDNA3 (including Strix Halo)
Hey everyone, I wanted to share GitHub - shisa-ai/hipEngine · GitHub - a new open source (from-scratch) inference engine that is a pure AMD ROCm implementation (all hot-path code is HIP/C++, all AMD libraries, PyTorch is expressly not a dependency) for RDNA3 GPUs.
It’s been mostly tuned on a spare gfx1100 (W7900, 7900 XTX) GPU, but I did an initial pass for gfx1151 (Strix Halo) support, and it ends up being faster than llama.cpp (HIP or Vulkan) basically across the board for Qwen 3.6 35B-A3B (basically the only model supported atm - you can think of hipEngine currently as closer to something like antirez’s DS4 than llama.cpp).
If you’re running a llama.cpp Vulkan variant, you should expect about 10% faster decode/token generation, and >2X prefill/prompt processing (much faster agentic/coding performance). Versus llama.cpp HIP, it’s up to 10% faster prefill/prompt processing (faster as context gets longer), and up to 30% faster decode/token generation.
Prefill tok/s
Workload hipEngine PARO llama.cpp HIP llama.cpp Vulkan
512/128 983.206 1058.738 638.008
4K/128 1029.402 1004.220 595.400
32K/128 792.296 735.534 407.984
128K/128 413.489 376.070 181.453
Decode tok/s
512/128 62.060 50.537 57.615
4K/128 63.605 49.379 55.027
32K/128 50.629 43.435 44.576
128K/128 30.245 31.286 26.935
I announced this on reddit last week to get some testers/eyeballs/feedback on this so it should be in good shape. If anyone tries it out, feel free to drop feedback or file an issue in the Github if you run into any problems.
  • There has been almost no Strix Halo specific tuning. I have some dedicated test hardware coming soon from Framework though and expect that I can squeeze more out of gfx1151 with some dedicated compute time.
  • There is decently fast Qwen 3.6 dense support, althought MTP/DFlash is still forthcoming so you may be better off with llama.cpp for that
  • I’m cooking up some new model support (StepFun 3.7, Gemma 4) and am open to requests.
  • This started off as a sort of thought experiment, but turned out to be worth sharing. I am working on c>1 perf now, and I will be porting some of my kvcache work, etc in my spare time. There’s not really a roadmap or anything, this is just for fun, but maybe it’ll be useful for some people!
  • The code is AGPLv3 (share-alike for reals), but I’ve also published a fair amount of docs/ that should be useful for anyone interested in RDNA3 GPU development, and includes extensive details on the AI-assisted kernel optimization approach used.
I did try it, but MTP beat it in my local setup (with nim coding etc) by about 30%. It seemed faster for the default, but couldnt’ handle mtp. Sadness.
MTP/DFlash are WIP atm, although it’s more of a grind than expected (verification is a bottleneck). Also, c>1 and a few other things (StepFun 3.7) are grinding away.
I’ll do a proper update soon now that I’m back from some out of town travel but a few good things:
  • I have a dedicated gfx1151 board courtesy of Framework now to do ongoing kernel grinding specifically for Strix Halo. Expect to see some big performance gains soon
  • MTP/DFlash is rapidly improving. On W7900/gfx11 we are now positive on 27B dense DFlash by 1.23X - 32.6 tok/s → 40.1 tok/s hipEngine/benchmarks at main · shisa-ai/hipEngine · GitHub
  • Concurrency, while not amazing, is also now running. I expect gfx1151 to benefit more than gfx1100. llama.cpp really falls apart at c>1 so this should be a durable improvement for anyone looking for fast multiuser/agent support: GitHub - shisa-ai/hipEngine · GitHub
A basic question: by “board” here, do you mean a standard Framework Desktop motherboard, or is this something that plugs into the PCI slot?
Standard bare motherboard, I’ve just plugged it in, so I’ll have this running in the corner and just grinding.
BTW @Thomas_Munn I just finished my MTP optimization pass. >AR is very hard for the Qwen 3.5 MoE (combinations of experts, attention, linear layers) but it is outperforming llama.cpp now so I assume that once I dig into the gfx1151, there will be a benefit.
Reproducible sweep script:
  hipEngine:scripts/llamacpp_vulkan_mtp_sweep.py
llama.cpp build:
  b9600 (263cc04a5)
  git describe: b9596-4-g263cc04a5
W7900 / Vulkan0, D32 prompt suite
engine / mode mean decode tok/s vs llama base MTP/AR speedup
llama.cpp Vulkan base 54.23 1.000x 1.000x
llama.cpp Vulkan B1 43.20 0.797x 0.797x
llama.cpp Vulkan B2 47.65 0.879x 0.879x
llama.cpp Vulkan B3 50.21 0.926x 0.926x
llama.cpp Vulkan B4 50.31 0.928x 0.928x
hipEngine current B1 113.39 2.091x 1.023x prompt-mean, 1.014x total-time
Best llama.cpp MTP: B4 at 50.31 tok/s.
hipEngine vs best llama.cpp MTP: about 2.25x.
Repro commands
llama.cpp Vulkan W7900:
  cd /home/lhl/hipEngine
  python3 scripts/llamacpp_vulkan_mtp_sweep.py \
    --gpu 0 \
    --max-tokens 32 \
    --draft-max-values 1,2,3,4 \
    --out-dir /tmp/llamacpp-mtp35-sweep-full-32
Also, here’s what c>1 looks like:
c hipEngine agg tok/s hipEngine per-seq llama.cpp Vulkan agg tok/s llama.cpp per-seq hipEngine / llama.cpp
1 116.68 116.68 106.47 106.47 1.10x
2 113.45 56.73 159.19 79.59 0.71x
4 156.03 39.01 70.44 17.61 2.21x
8 188.69 23.59 26.26 3.28 7.19x
llama.cpp’s c=2 is great actually, but it dies above that - at c=8, llama.cpp’s aggregate throughput is basically equal to hipEngine’s per-sequence performance (hipEngine is 7.2X faster total throughput).
For those following along, over the past month I’ve been grinding iterations on kernels, and it’s been interesting to see what’s shaken out. Thanks again to the folks at Framework for sending a dedicated motherboard to make this work possible.
While ROCm support/performance has improved dramatically since last year, there is still a gap between RDNA3 (gfx1100) and Framework Desktop RDNA3.5 (gfx1151). I actually just filed a new tracking issue for those interested: [Issue]: HIP/LLVM performance gaps versus RADV/Vulkan on gfx1100 and gfx1151 (RDNA3, RDNA3.5) · Issue #6409 · ROCm/ROCm · GitHub
(basically, Vulkan RADV/ACO appears to be in some important cases, much more performant than ROCm HIP/LLVM on RDNA3, and even more so for RDNA 3.5. I’ve built a new set of HIP vs Vulkan microbenchmarks that anyone can run if they’re interested).
So, what has a month or so of grinding on gfx1151 led to? Firstly, some big improvements on prefill and memory usage:
Prefill tok/s
Workload hipEngine PARO hipEngine GGUF llama.cpp HIP llama.cpp Vulkan
512/128 1140.101 430.767 1061.260 1067.770
1K/128 1208.343 437.467 1043.230 1069.870
4K/128 1089.031 403.946 1009.240 1016.580
32K/128 906.145 369.942 743.547 814.923
64K/128 716.775 334.395 573.611 660.974
128K/128 474.641 270.601 390.441 476.788
Decode tok/s
512/128 66.767 49.536 50.939 62.396
1K/128 61.746 52.192 50.818 62.136
4K/128 62.715 52.999 50.126 60.097
32K/128 50.342 43.947 44.240 51.319
64K/128 42.094 37.477 39.326 44.422
128K/128 30.386 27.862 32.114 34.948
Peak memory GiB
512/128 18.039 21.478 21.375 21.551
1K/128 18.051 21.710 21.387 21.501
4K/128 19.026 22.995 21.444 21.507
32K/128 19.729 23.559 21.987 22.191
64K/128 20.403 24.203 22.666 22.627
128K/128 22.124 25.493 23.862 24.254
Secondly, massively improved GGUF and GGUF+MTP support that basically matches llama.cpp. One thing worth noting here. It took much longer than expected to match llama.cpp - it turns out llama.cpp’s MTP implementation is very fast because it is not exactly numerically correct. I’ve retained an “exact” mode, where you do get some MTP benefit, but also have a “llama-compat” mode to match llama.cpp performance.
Metric hipEngine GGUF exact/default hipEngine GGUF llama-compat llama.cpp HIP
Route B5, fixed 10 cycles B2, natural24/cyclecap24 B2, natural25 request / 24 timed transitions
Canonical/native MTP decode 51.81 tok/s (0.9571x own AR) 69.50 tok/s (1.2776x own AR) 69.44 tok/s native (1.3752x own AR; not cross-engine comparable)
Cross-engine MTP decode-transition rate n/a: fixed-cycle horizon 69.38 tok/s 66.66 tok/s
Cross-engine own AR transition rate n/a: fixed-cycle horizon 54.40 tok/s 48.47 tok/s
Cross-engine MTP / own AR n/a 1.2755x 1.3752x
Draft acceptance 72.33% 77.72% 79.56%
Accepted draft/output 53.49% 59.58% 57.60%
Full-cycle/predicted wall per counted output or timed transition 19.360 ms/output 14.413 ms/output 15.001 ms/transition
State/commit contract exact/default, serial-prefix preserving direct partial commit/dp4a; accuracy-traded native llama.cpp compatibility target
Scope Prompts True AR tok/s llama-compat tok/s MTP / AR Draft acceptance Accepted/output Cycle wall/output
Full 10 54.40 69.50 1.2776x 77.72% 59.58% 14.413 ms
Train 6 54.44 70.96 1.3034x 82.08% 60.42% 14.116 ms
Heldout 4 54.33 67.42 1.2408x 71.79% 58.33% 14.858 ms
code 4 54.42 74.81 1.3747x 91.04% 63.54% 13.387 ms
general_en 2 54.50 67.62 1.2407x 71.79% 58.33% 14.811 ms
general_ja 2 54.40 66.60 1.2242x 69.23% 56.25% 15.042 ms
mixed_ja_en 2 54.25 64.90 1.1964x 69.23% 56.25% 15.438 ms
Now of course, all this work just to match llama.cpp isn’t all that impressive, but the next update will be c=N (updated concurrency numbers), which I think will be significantly more interesting.
BTW, v0.3.0 is just released w/ a lot of fixes: Release v0.3.0 · shisa-ai/hipEngine · GitHub
This is great work. I find the MTP findings quite interesting. Looking forward to further progress. Compared to last sept things are MUCH better. I do miss the exponential growth in “new model land” Its still cool that we are ‘good enough’ to code in weird languages like NIM with current home tech though!
@lhl I’m sorry for a noob question but is there some reason why llama.cpp HIP can’t be improved? I’ve been looking into adding a discrete GPU to this platform as the sparse experts are what the big memory pool are good for, but it seems like llama.cpp is the best backend for splitting across devices.
At first I hadn’t noticed how big the prefill speedup was from your work, there seems to be a lot of room for improvement.
llama.cpp HIP can be improved, but over the past couple years, I’ve seen that the maintainers simply do not take/prioritize submissions from outsiders for improving ROCm/HIP performance and are happy to leave things broken for months.
While I think it’s understandable and I have empathy for the maintainers since there’s a lot of lower quality work (especially in the age vibe-coding), fighting for trivial PRs isn’t high on my “things I like to do w/ my free time list.” llama.cpp also doesn’t really play so well with the things I wanted to experiment with (custom kvcache eviction schemes, higher concurrency kernels, etc) and since I had really good lucky building my own engine w/ FastDMS, I decided to just go my own way.
I think the trend for the Strix Halo community atm is to fork llama.cpp and just do their own thing for particular models/optimizations if you’re looking for something more llama.cpp-like (warning, a fair number of these have major quality/correctness issues):
NOTE: a bit part of why I started hipEngine was the intuition that an optimized HIP/ROCm path could perform better a lot better than Vulkan, but I think this is actually complicated because I found there quite a few cases where RADV/ACO outperforms HIP/LLVM: [Issue]: HIP/LLVM performance gaps versus RADV/Vulkan on gfx1100 and gfx1151 (RDNA3, RDNA3.5) · Issue #6409 · ROCm/legacy-rocm-build · GitHub
These have just been split into separate issues for those tracking:
Thanks for the answer. With LLMs being so competent I’m thinking of trying to custom patch what I can. One hacky llama.cpp compatible solution (I think…) to the multi-device problems I came up with is disabling MTP then running a separate draft model, since your results show llama.cpp HIP seems to be OK, but there’s major overhead in MTP.
I haven’t tested your hipEngine paroquant W4 (35b) for coding yet but will try it when I get back from vacation, also will see if I can quantize Ornith 1.5 the same way, but I think something closer to frontier is still a huge step up in productivity.
A couple warnings, while LLMs are good, they are also prone to mistakes and it’s easy to get in trouble vibe-coding with them. I have to take back my recommendation for Nathanw1014’s fork for example. While working on my Qwen 3.8 Flash Next implementation and testing/comparing numbers, I discovered that it fails repeatibility for all my test cases - on a 1024 token array, it produced 16 distinct continuations for 16 tries. (llama.cpp itself has some accuracy compromises, but they’re usually deterministic (or bounded bit-flips)).
BTW, while ParoQuant is very neat research [2511.10645] ParoQuant: Pairwise Rotation Quantization for Efficient Reasoning LLM Inference and I’m happy with my implementation, it is non-trivial to quantize compared to many other quant schemes (it can take days), so I’ve swapped to regular GGUF K-quants and have been working to make it as fast as my PARO path. I haven’t been at a good stopping point to cut a new release, but HEAD is generally working. Here’s what’s new:
  • Qwen 3.x MoE was my primary target but now Qwen 3.x dense (eg, Qwen 3.8 27B is performant as well)
  • Initial Qwen 3.8 Flash Next support, tuning now
  • Brand new concurrency engine - the prior one was efficient only with very specific submission windows, the new one does better continuous batching and should have much better real world performance (on W7900, same-protocol c1–c8 results improved by as much as 84% vs before)
  • New concurrency also supports better KV pooling and I’ve implemented DMS now as well which gives a lossless free halving for KV storage (not such a big deal for Strix Halo, but important for other GPUs)
  • MTP work is ongoing. It’s competent and beats llama.cpp HIP (but not Vulkan atm); system now does continuous specdec w/ better scaling to boot - n-gram proposals can compose as well, although I haven’t found the perf to be that strong in my testing. Basic DFlash2 support added too.
  • Added more reasoning effort controls and other serving support (max_completion_tokens, etc)
  • Lots and lots of new and improved kernels
For best coding models on a single Strix Halo, I think Qwen 3.8 27B and Qwen 3.8 Flash Next (122B-A6B) are by far the best. DS4 Flash is good, but I don’t think the quants that fit it into <128GB are doing it any favors. Same with GLM-5.3 Flash, which is much too large for a single Strix Halo.
I ordered a V100 with the idea of layer splitting the more often read weights. I haven’t written any of this CUDA/HIP stuff before, so my plan is have multiple coding agents take turns reviewing/debugging until it works :laughing:
From what I learned, the plan is to tap an early transformer layer to a custom trained draft head (which is small enough to quickly train on 1 GPU) to avoid PCI-e crossings for the draft tokens, and then all the LLMs seem confident they can rewrite some code to push the latency down to <20 microseconds x60-70 crossings per pass, might be able to hit 50t/s with MTP.
In relation to hipEngine but also in general, what do you think about ktransformers and the architecture they are proposing? maybe future en-gram model’s qwen4 and deepseek will align closer to splitting huge portions of the inference into CPU capable and GPU capable parts?
@lhl Any views on HRX yet? GitHub - ROCm/hrx-system: HRX: Hip Runtime Extended · GitHub
Hey been heads down on work, but in my spare time I’ve been continuing work on hipEngine - hipEngine v0.5.0 is now released and it’s a pretty big one.
The headline is now a very fast Qwen 3.8 27B implementation for Q4_K_M GGUF of anything out there (comparison). At c=1 pp512/tg128/mtp it’s 405 / 12.2 / 21.0 tok/s (competitively fast) but it also has the best concurrency scaling (c=1..8) that I’ve tested against:
Engine C1 C2 C3 C4 C5 C6 C7 C8
llama.cpp mainline Vulkan 10.226 17.471 14.905 13.246 18.086 24.083 29.342 35.376
llama.cpp stock HIP 10.635 17.681 15.266 13.537 18.271 23.296 26.544 30.325
Laurent Vulkan 11.047 19.835 16.359 14.255 20.294 28.322 35.896 45.614
Nathan Vulkan 11.162 19.662 16.341 14.321 20.099 27.575 34.317 41.511
q38rocm Vulkan 10.582 18.645 15.663 13.866 19.054 24.970 29.576 35.021
hipEngine 11.518 19.249 24.526 31.478 37.995 43.093 46.153 50.605
BTW, there is also very good MTP support now for all the Qwen models. By default the engine intelligently switches on/off MTP based on concurrency (profiled speed) but you can also override and turn it on/off on a per request if you want:
Model Quant Prompt processing Text generation With MTP Max context
Maple-Preview 2-bit 754.5 153.2 — —
Qwen3.6-35B-A3B GGUF UD-Q4_K_M 1369.5 54.3 80.1 —
Qwen3.8-27B Dense GGUF Q4_K_S 396.1 13.1 23.9 —
Qwen3.8-27B Dense GGUF Q4_K_M 404.5 12.2 21.0 —
I’ve started optimizing Qwen 3.8 Flash Next, but there are a lot of neat forks out now (with varying levels of correctness/accuracy), I think GitHub - halo-box/strix-llama.cpp: LLM inference in C/C++ · GitHub is the most promising (community fork, not worrying about being slavish to upstream llama.cpp), so for popular models, that may be best (they’re moving very quickly), but probably the more interesting things with hipEngine now from my most recent work:
  • I’ve overhauled the concurrency engine - it has true continuous batching, shared kvpool, and radix prefix caching - hipEngine has always been more of a a mini vLLM/SGLang than llama.cpp, and that continues
  • hipEngine was built with DMS support in mind, and that promise is now fulfilled. It now has a demonstrated 5.7x KV cache compression with 100% Top-1 and 0.001 KLD (much more accurate than even direct INT8 KV)
  • I’ve been adding a bunch of models I’m interested in. Moonshine realtime-ASR, TimesFM time series, EVIE late interaction visual document retrieval - these don’t have llama.cpp or (any non-torch inference support) at all. I’ll be adding more modalities and things that I think are cool now that the engine is working well. I’ve begun using bits and pieces for production workloads even.
  • There’s a lot of QoL stuff focused around running/agentic work - auto-calculation of memory pools when loading, logit-biasing and other reasoning adjustments, per-request MTP (and default MTP so it only applies when it gives a speedup), etc. Neat stuff I think an inference engine should do.
@_sk Engrams are very cool, Qwen 3.8 Flash Next is pretty great. The more o(1) math the better. I’m also enjoying DS4.1 Flash, but it’s too big for 2xStrix Halos atm. For fun right now I’m having ds41f tune itself: GitHub - shisa-ai/ds41f · GitHub
@Anders_Rudkjaer_Norg haven’t looked at HRX. I think for people looking to have fun/poke, go for it, but it’s too early to tell how far they’ll get. I don’t think it’s super relevant to my work. For low level perf I’ve been submitting what I’ve noticed into LLVM/HIP/ROCm repos and they are making their way through.
For those interested in lower level RDNA3 GPU stuff, I’ve distilled this doc recently: hipEngine/docs/RDNA3-TUNING-GUIDE.md at main · shisa-ai/hipEngine · GitHub
Hello, thanks for taking the time to share this. Is it supported on Windows?
I’ve never tested it on Windows. You could give it a spin (but I’d guess it probably doesn’t work).
if you install now btw, try to do so from source HEAD. I’ve pushed a bunch of MTP/prefix cache fixes (was off by default in the v0.5.0 review, oops). v0.6.0 w/ a lot of new stuff will be out soon, but there’s also real-world improvements on agentic flows w/ improved prefix caching especially:
I pushed v0.6.1 out, which fixes some niggles with the engine itself (there a bunch of cases where MTP or prefix caching was being improperly gated, also sampling was not optimized, had to revamp that, should all be running at full speed now).
I’ve actually been working on a bunch of fun things like additional unique model support:
  • There is now full Surya OCR 2 support for SOTA document OCR (multilingual support, layout analysis, table recognition)
  • I also added Microsoft VibeVoice ASR and 1.5 TTS and actually have no non-torch way of running, so should be useful. (they run in hipEngine faster than Torch of course).
Also, just added an internal benchmark to the chat so you can see how MTP and prefix caching affect performance:
BTW, just a monthly update, I’ve just pushed out the latest release, v0.8.3. Topline features include:
  • Gemma 4 26B-A4B text inference support. On average it’s about 20-30% faster in prefill and decode than anything else, out there, added this since recently I’ve been training some Gemma 4 26B based decision models. w/ MTP, it outputs at ~70 tok/s decode
  • Decently fast Qwen 3.8 Flash Next support (with UD-Q4_K_XL weights 4K prefill is 1650 tok/s, which is faster than strix-llama.cpp and just behind gufo) - hipEngine has 39 tok/s 4K MTP decode as well, which is neck and neck w/ gufo as well - if qwen38fn is your main goal, you might want to try out one of the of the many other inference frameworks, but hipEngine is in a good spot I feel like, and prefix caching and concurrency should work well also
  • I spent a bunch of time implementing and tuning YuE2-3B song generation - it RTF is about 3-4X so it’s not a speed demon, but you can generate Suno V5-competitive songs locally, which is pretty neat (and about 2X faster than upstream PyTorch implementation).
Other improvements:
  • Less relevant for Strix Halo, but automatic context sizing is substantially improved on 24GB GPUs, accounting for prefill scratch, speculative verification, prefix snapshotes, and shared-cache reserves. on a 24GB 7900 XTX, w/ DMS enabled, Qwen 3.8 27B can run with full 256Ki context at practically zero accuracy loss
  • The MTP route is substantially improved, offering logprobs and full sampling and other things that hipEngine and many other implementations were previously missing
  • A bunch of streaming reply report improvements
There are a lot of choices for vibe-coded fast inference on Strix Halo these days, and this remains a spare time/in the background hobby project, but I’m pretty happy in terms of the performance, features, and model support for hipEngine atm, and will be spending the next cycle on cleanup and reliability. This repo has grown pretty gargantuan over the past 6mo or so (500K sloc or pure code) and I’ll be aiming to aggressively streamline.
