Hello my framework just arrived and I’ve already set it up with windows running on it since I needed to install the drivers. This is my first laptop and afaik the touchpad should register a click when I click it physically in the bottom left/right, however that doesnt work only tapping the touchpad registers a click. Is this normal? or is something wrong with my laptop?
There are three buttons on the bottom of the touchpad. Pressing them you should feel and hear the click. The middle button is larger than I was prepared for. But definitely if you’re pushing the corners, they should work.
SOLVED
Followed the knowledge base guide on what to do if it’s not working
I think it’s just one big button, but the driver tries to detect where your finger is pushing to emulate multiple buttons.
