Multiple Touchpad Problems
  • Tapping to left click and tapping right click work as expected, BUT
  • Physically clicking to left click works 50% of the time
  • Nowhere on the touchpad is able to physically right click
This is a significant issue for me, since I prefer to physically click, and I need to be able to click and drag things.
Do I need a driver update? What’s going on here?
What’s your OS and BIOS version and batch and, y’know, laptop info?
I had this problem when I received my laptop:
From My touchpad isn't working
There were also a small number of early units produced that may have contact issues on the physical switch on the Touchpad. Try pressing the bottom middle of the Touchpad firmly a few times to see if that resolves the issue. If it does not, please contact Framework Support.
The thing about ‘small number of early units’ was misleading, since I was in batch 5 and I had this exact issue exactly fixed by the suggested resolution.
OS: Windows 10 (fresh install)
BIOS: 3.0.7 (just updated this a literal minute ago because I want the charge limiter)
Batch: 6
Firmly pressing down on the bottom middle of the touchpad resulted in a right click the first couple times I did it, but it did not fix the issue at first, but as I typed this it seemed to start working lmao.
Thanks!
You’re welcome!
@Framework Please someone update the knowledgebase. The thing about
early units
is evidently wrong and misleading.
Hey, I’m just impressed with how helpful this community is. Hopefully I find the opportunity to pay it forward to other new users.
Darn, the problem came back… are there any other fixes that I should try? Do I just keep squishing the mousepad when it misbehaves? That seems a little janky…
(to be clear, I am willing to accept some level of jank as an early adopter)
@Matthew_Elmer, is the touchpad physically clicking? That is, you get a mechanical click, but nothing registers in software? If so, that sounds like a driver issue.
If it is not clicking or is rubbing, you may want to try the steps in the Touchpad Rubbing Fix Guide that’s on the page linked above. Also, check the connections on both ends of the cable.
If none of those work, your next step likely will be to open a ticket with Support. Best of luck.
Yes, I am getting a mechanical click, but nothing registers in software. I’ll try updating the drivers.
Not sure if this helps, but my Framework (Batch 3 IIRC) had a similar issue where the mouse would “click” but no click was registered.
In my case, I had to take the trackpad out of the top cover, and then remove and re-apply the sticker containing the metal contact that acts as the “button”. It seems for some reason mine drifted with time, preventing it from making a circuit even when it made a click noise. After removing and re-centering mine, I have had no issues.
If it helps, the part in question looks like one of these, and has a transparent adhesive sticker holding it to the board.
https://m.media-amazon.com/images/I/310IJvwHlaL.AC.jpg
Reinstalling the latest drivers didn’t fix it. I’ll give @Chris2’s solution a shot.
Actually, @Chris2, is there any guide that I can follow? Or a set of steps? I opened it up but I don’t want to go disconnecting those tiny connectors before I really know what I’m doing.
It should be noted that the simple act of opening the laptop up and fiddling around with (clicking) the touchpad from inside and outside at the same time has given me a solid 90% chance for the touchpad to work as expected. I think it’s a hardware issue. I just wish there was a permanent fix.
Sadly I don’t have a guide, but if you follow this you can use it to walk you through removing the touchpad:
The part I mentioned you can see in photo https://d3t0tbmlie281e.cloudfront.net/igi/framework/iFHTfSFBHrJTTfqZ.huge
It’s that silver dome at the bottom center that acts as the “button”, it’s just held on with an adhesive layer on top. Just remove, recenter, and try that. Just note that you need to be careful removing it. I used a dull exacto knife for the act, but you NEED TO BE CAREFUL NOT TO SCRATCH THE BOARD.
This is most likely a hardware issue, refer to this thread for more information about it. I also have this problem and I still don’t have this resolved. Pressing in the bottom middle part of the touchpad will work sometimes.
Update: My (replaced) touchpad still has intermittent issues. Sometimes it will click without me tapping! Very frightening when using a gui that allows you to delete things. I don’t have any helpful data to give, but I did want to let it be known that I am still having issues.
Yes I am also having huge issues with the trackpad. I’m on my third input cover this year, yet after a month to three months of use my trackpad stops working with physical clicks. I’m hoping this gets resolved soon in the future.
Update: it seems to have something to do with temperature. The hotter my laptop gets, the worse the touchpad misbehaves.
Update: Clicking with the touchpad is now unreliable regardless of temperature. When I put pressure on the places where you’re meant to rest your palms, or hold it by that same place, clicks do not work at all. If I touch only the touchpad while clicking, it works about 33% of the time after I find the right spot.
Just linking a short and relevant thread with a bit more information on input covers: Have the input covers been fixed?
This sounds like chassis flex is interfering with the physical click, I have experienced this and seen other posts like this Touchpad automatically depressing when chassis flexes.
That sounds like a different problem, have you tried disabling palm rejection or related settings like disable mouse while typing for testing?
Disabling PS/2 emulation in the BIOS was a suggested fix I saw in other similar threads but I don’t know if that will help.
I’m a little confused as to why you didn’t get a new input after the replacement was also not working? As long as the issue was present before your warranty expired or within 90 days of the replacement I would think you should be entitled to a replacement.
Have you contacted support recently?
Ooh, yes, that has happened to me too.
I wouldn’t want to disable palm rejection, but I guess I could try. I remember fiddling with some settings back when I first started having issues, but I should double check these.
The issue didn’t go away after the first replacement, and I had no reason to believe further replacements would be any better. I’m a very busy student, so I didn’t (and don’t) have time to be shipping and swapping input covers repeatedly.
Nope. This is a good idea. I usually think of contacting support as something you do for warranty purposes, but it would make sense to simply talk to the tech experts and see if they can help.
