Hi,
how can I connect an eithernet cable of the laptop. As far as I saw it does not have a RJ45 jack.
Thanks,
mipi
There any many usb-c to Ethernet adapters available.
In addition, at least one person is designing a plug-in module to do it.
You’ll need a usb type a or usb type c expansion card to go along with a usb type a or usb typc c ethernet adapter.
There will also be an official ethernet expansion card but the release date is currently unknown
Yes, Real Soon Now, as the author of the Chaos Manor column in the old Byte magazine used to write.
I am the unofficial creator of Ethernet compatibility with framework. expect more updates in the next few weeks as I’ve sourced everything for first prototypes.
Thanks a lot to all of you for the quick responses!
