I am hoping to upgrade my mobo, move the existing mobo to the 3d printed case on your github site, and ensure the mobo is protected with a battery such as LiFePO4 USB-C PD connection.
Is the mobo able to smart-charge such a battery? What external battery would you recommend using? I’m hoping to do Bitcoin/Lightning/Radix DLT validation with a redundant USB-C wired + USB cell stick network.
Thanks.
