Fedora 44, kernel 7.1.8, BIOS 4.05 on AMD Ryzen™ 7 7840HS with Radeon RX 7700S
How can I monitor CPU power consumption? I don’t see it in sensors or btop or s-tuior htop. The only thing I can think of to do is look at overall system power consumption in btopwhen system is idle, then run stress and see what it spikes to.
Has anyone found a way to do this?
Edit: I’m thinking that the power draw for the integrated GPU would be a better proxy. What do you think?
