How to remove dust from framework laptop
Hi,
my impression is that the laptop fans are turning on more frequently in recent times. I’m not sure what the cause is, but it could be dust accumulation and that is why I want to take the laptop apart and clear it out. A bit of spring cleaning is probably a good idea anyway.
I found the Fan and Heatsink Replacement Guide which explains how to unscrew the fan and heatsink. But the guide also talks about thermal paste. I have never worked with thermal paste before and I want to make 100% sure that I am well-prepared when I remove the fan and heatsink. I found this post:
And that post describes the need to reapply thermal paste. Is that correct? Or can I temporarily take out the fan without needing to reapply thermal paste? Does the thermal paste stick to the heatsink or fan?
The thermal paste will stick to the heatsink, there’s no real need to re-apply thermal paste, since it won’t be going anywhere! That being said, re-applying thermal paste can have benefits for your thermals too, if you’re willing to go out and buy some. Everything will make sense once you’ve lifted the fan off, hard to explain.
Have fun cleaning though!
your wrong when the thermal paste heats up it changes from a liquid to a viscous crap. When you take the heat sink off you always… ALWAYS reapply the thermal paste as it doesnt spread and provide a decent contact to the heat sink anymore!
That’s interesting! From anecdotal evidence and imperical testing I’ve done, there hasn’t been any difference in temperatures after re-applying the heatsink.
I don’t believe traditional thermal paste undergoes any phase/viscosity changes after heating either, as it is generally some sort of oil-based mixture.
If you have extra thermal paste on hand, it obviously doesn’t hurt though !
Why do you need to remove a heat sink and fan to remove dust?
If you remove the whole mainboard you can then reach everywhere that might get dusty and blow or lightly brush all the dust away.
thats also a lot of effort when they could just put the screws on the other side!
https://www.google.com/search?client=firefox-b-d&q=do+i+need+to+reapply+thermal+paste+whe+i+remove+the+heatsink
Am also just now running into this issue after assuming de-dusting the fans would be a simple maintenance job for a modular laptop. Am now wondering if I just do the best I can to get out what dust I can with without removing it with just what I can find about the house, or if I have to actually get to the shops before this weekend to find somewhere selling thermal paste before I can just clean out whatever causing the fan to clatter (I’m presuming a hair got caught in there or something). Woulda thought there’d be a simple screw to remove the fan cover and gently tweeze/toothpick whatever’s caught in there.
So everyone is going on about honeywell thermal pad’s soo I would go with that instead of paste. also dont run your computer at 100% in full power mode. I also put heater spreaders on the ram and ssd to conduct the heat to the keyboard!
also if you remove the fan dont put the fan screws back in(screws on fan, small ones) then you can easily take a fan out without repasting.
