I'm assuming USB-C is thunderbolt enabled now?
It doesn’t mention Thunderbolt in the specs at checkout
SEE IMAGE:
The thunderbolt standard since version 3 uses a usb-c connector.
The usb-c is just a stright extender so in a thunderbolt port it’s thunderbolt, in a usb2 one it’s usb2.
That’s not a problem on the intel ones because all ports are thunderbolt but on the amd only the back 2 are usb4 (full featured) and the front 2 aren’t
