Hello, not sure what all information ya’ll need to debug this, but I’ve determine that my Computer’s WIFI is having performance problems when streaming games to my laptop from my desktop.
(The moonlight-qt (client) <-> Sunshine (host) setup)
When I plug ethernet into the laptop, I have 0 problems, no lag, no stutters, etc.
The problem with the wifi seems to be ~ every 5 minutes or so.
I’ve seen these related posts / threads about my problem, and it seems nothing helps
- networking - Kubuntu 22.04 - wifi freeze after hwe kernel upgrade to 6.5 (was fine on 6.2) - Ask Ubuntu
- networking - Ubuntu keep disconnecting me from 5 in 5 min from any network - Ask Ubuntu
- networking - Ubuntu 23.10 wifi connects and disconnects every few seconds with 0bda:c811 Realtek adapter - Ask Ubuntu
- https://www.reddit.com/r/pop_os/comments/163bbrb/slow_wifi_speeds_with_ax210/
- networking - Disable wifi power management - Ask Ubuntu
- Poor network connection on excellent network · Issue #79 · moonlight-stream/moonlight-android · GitHub
- Occasional stutters, lag, "reduce bitrate message", otherwise handles well over 80mbps just fine · Issue #1367 · moonlight-stream/moonlight-android · GitHub (an issue I opened tracking some debugging information about streaming between computers in general – ignore the fact I opened this on the android repo – that was a mistake – I was tired
wondering if anyone else has both ran in to this, and known what to do about it? I think my problem may be related to power-save features – but I can’t seem to be able to turn them off. For gaming / streaming from the PC, ya don’t really want power saving until you’re done playing. ![]()
Here is my wifi card info:
❯ lspci
01:00.0 Network controller:
MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
❯ iwconfig
lo no wireless extensions.
wlp1s0 IEEE 802.11 ESSID:"[....]"
Mode:Managed Frequency:5.765 GHz Access Point: [....]
Bit Rate=866.7 Mb/s Tx-Power=3 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=60/70 Signal level=-50 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:3 Invalid misc:164 Missed beacon:0
