Internal USB device produce a lot of errors and warnings in journal
Arch
Which release version?
Yesterday
Which kernel are you using?
6.15.3
Release
Ryzen AI 300
I have a lot of messages about failedpower state transition in my journal.
I also asked in arch forum for help:
But maybe someone knowing this laptop knows what propably internal device is connected to 3-5.
First it was only
kernel: xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
After installing the upd72020x-fw fiemware there are a lot more.
Jun 23 22:38:28 rahmen kernel: usb 3-5: device descriptor read/64, error -110
Jun 23 22:38:22 rahmen kernel: usb 3-5: new high-speed USB device number 19 using xhci_hcd
Jun 23 22:38:22 rahmen kernel: xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
Jun 23 22:38:21 rahmen kernel: usb usb3-port5: unable to enumerate USB device
Jun 23 22:38:21 rahmen kernel: usb 3-5: device not accepting address 18, error -62
Jun 23 22:38:21 rahmen kernel: xhci_hcd 0000:c3:00.0: Timeout while waiting for setup device command
Jun 23 22:38:15 rahmen kernel: xhci_hcd 0000:c3:00.0: Timeout while waiting for setup device command
Jun 23 22:38:10 rahmen kernel: usb 3-5: new high-speed USB device number 18 using xhci_hcd
Jun 23 22:38:10 rahmen kernel: usb 3-5: device not accepting address 17, error -62
Jun 23 22:38:10 rahmen kernel: xhci_hcd 0000:c3:00.0: Timeout while waiting for setup device command
Jun 23 22:38:04 rahmen kernel: xhci_hcd 0000:c3:00.0: Timeout while waiting for setup device command
Jun 23 22:37:59 rahmen kernel: usb 3-5: new high-speed USB device number 17 using xhci_hcd
Jun 23 22:37:58 rahmen kernel: usb usb3-port5: attempt power cycle
Jun 23 22:37:57 rahmen kernel: usb 3-5: device descriptor read/64, error -110
Jun 23 22:37:42 rahmen kernel: usb 3-5: device descriptor read/64, error -110
Jun 23 22:37:36 rahmen kernel: usb 3-5: new high-speed USB device number 16 using xhci_hcd
Jun 23 22:37:36 rahmen kernel: usb 3-5: device descriptor read/64, error -110
Jun 23 22:37:20 rahmen kernel: usb 3-5: device descriptor read/64, error -110
Jun 23 22:37:15 rahmen kernel: usb 3-5: new high-speed USB device number 15 using xhci_hcd
Jun 23 22:37:13 rahmen kernel: usb usb3-port5: unable to enumerate USB device
Jun 23 22:37:13 rahmen kernel: usb 3-5: device not accepting address 14, error -62
I have in the bays in the back two usb-c cards. In the front left USB-A and in the front right an SD-Card reader which is empty.
You can use lsusb command to check which device is hidden under the name of “usb 3-5” :slight_smile:
None?
Bus 001 Device 002: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix Fingerprint USB Device
Bus 003 Device 002: ID 32ac:001c Framework Laptop Webcam Module (2nd Gen)
Bus 003 Device 003: ID 0e8d:0717 MediaTek Inc. Wireless_Device
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Strangely today only the power state message is present. I had all the other messages consistently between several reboots. With Mic and Camera switched on and off.
I am unsure what USB 3-5 actually refferes to.
I tried out the external ports of the Laptop with different devices.
Back right is USB-C with my phone resulting in journalmessage
kernel: usb 5-1: new high-speed USB device number 7 using xhci_hcd
with lsusb
Bus 005 Device 007: ID 18d1:4ee1 Google Inc. Nexus/Pixel Device (MTP)
back left with USB-C
kernel: usb 7-1: new high-speed USB device number 7 using xhci_hcd
Bus 007 Device 007: ID 18d1:4ee1 Google Inc. Nexus/Pixel Device (MTP)
front left with USB-A
kernel: usb 3-1: new high-speed USB device number 7 using xhci_hcd
Bus 003 Device 007: ID 058f:6387 Alcor Micro Corp. Flash Drive
front right SD reader
kernel: usb 4-2: new SuperSpeed USB device number 15 using xhci_hcd
Bus 004 Device 015: ID 32ac:0009 Framework SD Expansion Card
I shortly thought that 3-5 would refer to BUS 3 and device 5, but looking on the data above, it doesn’t.
I guess it has to be BUS3, but probably an internal device.
Other devices listed on BUS3 are:
Regarding the other messages about the power states I looked at the following:
journalctl -b | grep xhci_hcd
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c1:00.4: xHCI Host Controller
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c1:00.4: new USB bus registered, assigned bus number 1
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c1:00.4: hcc params 0x0118ffc5 hci version 0x120 quirks 0x0000000200000010
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c1:00.4: new USB bus registered, assigned bus number 2
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c1:00.4: Host supports USB 3.1 Enhanced SuperSpeed
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.0: xHCI Host Controller
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.0: new USB bus registered, assigned bus number 3
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.0: hcc params 0x0128ffc5 hci version 0x120 quirks 0x0000000200000010
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.0: new USB bus registered, assigned bus number 4
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.0: Host supports USB 3.1 Enhanced SuperSpeed
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.3: xHCI Host Controller
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.3: new USB bus registered, assigned bus number 5
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.3: hcc params 0x0118ffc5 hci version 0x120 quirks 0x0000000200000010
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.3: new USB bus registered, assigned bus number 6
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.3: Host supports USB 3.1 Enhanced SuperSpeed
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.4: xHCI Host Controller
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.4: new USB bus registered, assigned bus number 7
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.4: hcc params 0x0118ffc5 hci version 0x120 quirks 0x0000000200000010
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.4: new USB bus registered, assigned bus number 8
Jun 24 12:14:45 archlinux kernel: xhci_hcd 0000:c3:00.4: Host supports USB 3.1 Enhanced SuperSpeed
Jun 24 12:14:45 archlinux kernel: usb 1-1: new full-speed USB device number 2 using xhci_hcd
Jun 24 12:14:45 archlinux kernel: usb 3-3: new high-speed USB device number 2 using xhci_hcd
Jun 24 12:14:46 archlinux kernel: usb 3-5: new high-speed USB device number 3 using xhci_hcd
Jun 24 12:15:09 rahmen kernel: xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
So I guess 0000:c3:00.0 is USB Bus 4. Which could be related to the SD-Card reader.
You could also check this thread:
Some error messages there look similar to your problem…
I am stupid grep for 3-5 sows that 3-5 is the wifi card, which I will replace anyway, because it is not really stable.
So 3-5 is solved. But the power state is still unclear to me.
Okay it seems to be the SD-Card reader. As soon as I plug in an SD card, the spamming to journal stops. But if I remove it, it will spam again.
If I connect nothing or another USB-A card, I still get the same power state message. Only if I plug something into the USB it gets quiet.
That seems a bit strange to me. Should I contact the technical support?
Swapping USB-A and SD card reader latter now in slot 2 and first in slot 4 stopped the messages. Thats kind of strange.
I am observing the same behavior on Fedora 42 right now.
I’ve sent a support request and I’ll update here when I know more.
Thanks for your documentation of the issue, saved me a lot of work :slight_smile:
I’ll also point to the below topic that may or may not be related. I didn’t want to derail it there but in case this turns out to be related, we already have it here: AMD GPU MES Timeouts Causing System Hangs on Framework Laptop 13 (AMD AI 300 Series) - #13 by Mario_Limonciello
I received an answer, simply stating that this is expected behaviour, which is a bit unsatisfying.
Why should I expect that a reasonable hardware config produces so much spam.
I’ve only now discovered the knowledge database article about the ports on the Ryzen AI 300 series and it’s here https://knowledgebase.frame.work/en_us/expansion-card-functionality-on-framework-laptop-13-amd-ryzen-ai-300-series-Hy5SfMRs1l
I knew about this for the Ryzen 7040 series and actually checked before ordering the AI 300 but obviously must have overlooked the article when I checked for it.
However, it does not mention the logspam and it doesn’t clearly mark port 2 as problematic like it does for port 1 and 3. The table below the graphic states that port 2 has slightly higher power consumption with a USB-A port inserted.
Especially the log spam is super annoying. Consuming battery is one thing, but not being propperly setup, just because one has an USB-Adapter connected is another thing.
