One use case I will be testing, that I’m not sure if its been tested yet is running a VM on the Framework laptop then passing my egpu dock through to the VM. I can see a potential issue arising where maybe it will not be possible to separate the separate thunderbolt ports into different IOMMU groups and only passing the port for the egpu through to the vm maybe impossible.
I’ll let you know when I get mine and test, but just wanted to bring it up here to see if anyone else has tested this use case.
