I have a Framework Desktop, and I’m wondering if there’s any way to use the display from a Framework Laptop 12 as an external monitor for it.
I understand that laptop displays usually don’t accept video input directly, but I wanted to ask whether Framework offers (or plans to offer) any supported solution, or if there are any practical workarounds (software-based, capture cards, display controllers, etc.).
Has anyone tried something like this, or knows if it’s feasible with Framework hardware specifically?
There’s another thread in the framework laptop forums discussing this.
TL;DR: the display connector on the monitor (not the motherboard) looks like it’s a standard 30-pin eDP connector, and there are lots of inexpensive driver boards that should work for that. However, if you also want to keep the touchscreen functionality, there’s probably not a drop-in solution.
