I ask because I’ve had Ubuntu 22.04 LTS freeze up on me a couple of times and one way to reboot, I think, is Alt + SysRq + B. It’s only happened twice and I’ve held the power button down until it powers off but that isn’t desirable right?
Is there a better way to come out of a completely locked up laptop?
I can’t really pinpoint whats causing it. Today I was exploring some of the installed apps I haven’t looked at before.
Print Screen can stand in for SysRq!
If you are using the magic sysrq incantation to reboot, make sure you give it a chance to sync and unmount filesystems as well! The sequence I was taught was (Alt+SysRq+) R E I S U B.
Thanks, I read about (Alt+SysRq+) R E I S U B.
Might be tough hitting all the keys while holding down Alt+SysRq but I’ll give it a try next time.
Ah, I may be missing a joke (sorry!) but you can enter the characters sequentially
