Just got my 1340p model few days ago.
After doing some search in community, I have monitor my modern standby (s0 sleep with network disconnected in battery) battery drain is like following:
curious is it a normal case since I can hardly found someone who is okay with modern standy to show their sleep study statistics.
by the way,
the hardware specs are:
CPU: 1340p
SSD: P44 Pro 2TB
RAM: 32GB * 2
OS info:
all the drivers installed
sleep status:
updated some new data:
I’m going to take a wild guess that you have at least one of the following expansion card plugged into at least one of the 4 expansion slots:
USB-A
micro-SD
HDMI
DP
Storage
USB-A
micro-SD
HDMI
DP
Storage
unfortunately I only have 4 Type-C expansion slots
In that case, that’s definitely higher than one would expect.
Thank you, any idea on why it happend?
by the way, I have updated the a new sleep data
The other cause that we’ve seen in the past (previous gen) is audio playing in a browser → sleep…and that somehow kept the CPU active.
We’re still pretty thin on 13th gen end user reports…you’re the first.
Interesting, But I close the lid for sleep without any tab play audio in browser or other apps
Can we assume that you have the driver bundle installed?
Think you’ll need to open a case with Framework Support then. This might be some kind of BIOS related matter. A happy path experience shouldn’t have high sleep / suspend drain.
thank you, will do what you suggest
Banana
May 22, 2023, 5:16am
#12
See High Battery Drain During Suspend (Windows edition) . 257 posts of goodness to scroll through. My FW also used to consume 5W during suspend. Yours isn’t too terrible overall.
