I’m using PopOS 21.10.
I managed to get my lg free tone fp9 to pair with the OS.
I can’t manage to find it as an option in the sound settings, and when I try to select it via pavucontrol the system still doesn’t recognize it nor directs the output. So no sound.
I tried following: Bluetooth Troubleshooting - System76 Support
Any way I can fix this?
Not sure if you’re using Pipewire, you can check by running pactl info | grep '^Server Name'
If you aren’t, give the following a go:
https://www.reddit.com/r/pop_os/comments/ofdalv/replaced_pulseaudio_with_pipewire_on_popos_2104_i/
