I am having issues with running OSs on my storage expansion cards. What happens is that when I am using whatever OS/distro is installed, it will randomly freeze up completely. The freeze up could happen after 5 minutes of use or after 10, 23, etc. It also happens when actively in use (i.e. typing), or when sitting idle at the lock screen. I have to force restart the laptop to get it working again.
I have 4 storage cards in total (2 250GB & 2 1TB). I have installed different distros on all 4 and they all give me the same issue (Fedora 35 & 36, Ubuntu 22.04 & 21.10, and Pop!_OS 22.04). I also tried with Windows 11 on one of the cards and same thing.
All 4 cards were not bought at the same time. I also added the thermal pad to all of them.
I did some testing with all 4 on Windows using CrystalDiskMark (9 passes, 64GiB) and just transferring large video files and I had no issues. They did get hot but not to the point to throttle.
I can run any of those OSs on an NVMe without any issue, so I am stomped.
Anyone have any ideas?
I’m just spitballing but it sounds like perhaps the Thunderbolt controller is disconnecting at idle? I know you said in use but typing would be located in RAM and wouldn’t touch storage until the file is saved. I haven’t a clue on how one would diagnose such a thing but that’s what comes to mind for me.
@GhostLegion So I am running on the newest BIOS (3.07). In the BIOS it shows both PD Controller versions as 3.4.0.2570. Not sure if there is a way to update the firmware manually.
@GhostLegion I was going to do that yesterday but I thought to ask here first, maybe someone would have an idea on things to try before reaching out to support.
So I realized that I hadn’t tested all the ports. I thought that it would be the same thing on all ports but after testing, I was wrong. Weirdly enough, it still worked after an hour, running Ubuntu 22.04 on the top right port using the 250GB card.
I guess that something is wrong with the USB controllers on my laptop. Time to contact support.
