powertop reports an idle power usage of 7-8W. I have no idea what’s using the power, because the cpu is at <1% usage and the gpu is at ~5% usage when idling. Powertop says the wifi adapter is using 10W (which is more than the total power usage?), so I don’t think I can trust anything but the overall usage in there. The battery is draining fast enough to suggest 7-8W usage, though (only 4-5 hours of battery life idling).
I am using a sdd and wifi card from an old laptop, but I don’t think they could drive the idle up that much.
I have configured the correct settings, I will attach the output of tlp-stat as well:
--- TLP 1.4.0 --------------------------------------------
+++ Configured Settings:
defaults.conf L0004: TLP_ENABLE="1"
defaults.conf L0005: TLP_WARN_LEVEL="3"
defaults.conf L0006: TLP_PERSISTENT_DEFAULT="0"
defaults.conf L0007: DISK_IDLE_SECS_ON_AC="0"
defaults.conf L0008: DISK_IDLE_SECS_ON_BAT="2"
defaults.conf L0009: MAX_LOST_WORK_SECS_ON_AC="15"
defaults.conf L0010: MAX_LOST_WORK_SECS_ON_BAT="60"
defaults.conf L0011: CPU_ENERGY_PERF_POLICY_ON_AC="balance_performance"
/etc/tlp.conf L0117: CPU_ENERGY_PERF_POLICY_ON_BAT="power"
/etc/tlp.conf L0152: SCHED_POWERSAVE_ON_AC="0"
defaults.conf L0014: SCHED_POWERSAVE_ON_BAT="1"
defaults.conf L0015: NMI_WATCHDOG="0"
defaults.conf L0016: DISK_DEVICES="nvme0n1 sda"
defaults.conf L0017: DISK_APM_LEVEL_ON_AC="254 254"
defaults.conf L0018: DISK_APM_LEVEL_ON_BAT="128 128"
defaults.conf L0019: DISK_APM_CLASS_DENYLIST="usb ieee1394"
defaults.conf L0020: DISK_IOSCHED="keep keep"
defaults.conf L0021: SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
/etc/tlp.conf L0236: SATA_LINKPWR_ON_BAT="min_power med_power_with_dipm"
defaults.conf L0023: AHCI_RUNTIME_PM_ON_AC="on"
defaults.conf L0024: AHCI_RUNTIME_PM_ON_BAT="auto"
/etc/tlp.conf L0261: AHCI_RUNTIME_PM_TIMEOUT="5"
defaults.conf L0026: PCIE_ASPM_ON_AC="default"
/etc/tlp.conf L0344: PCIE_ASPM_ON_BAT="powersupersave"
defaults.conf L0028: RADEON_DPM_PERF_LEVEL_ON_AC="auto"
defaults.conf L0029: RADEON_DPM_PERF_LEVEL_ON_BAT="auto"
defaults.conf L0030: RADEON_POWER_PROFILE_ON_AC="default"
defaults.conf L0031: RADEON_POWER_PROFILE_ON_BAT="default"
defaults.conf L0032: WIFI_PWR_ON_AC="off"
defaults.conf L0033: WIFI_PWR_ON_BAT="on"
defaults.conf L0034: WOL_DISABLE="Y"
defaults.conf L0035: SOUND_POWER_SAVE_ON_AC="1"
defaults.conf L0036: SOUND_POWER_SAVE_ON_BAT="1"
defaults.conf L0037: SOUND_POWER_SAVE_CONTROLLER="Y"
defaults.conf L0038: BAY_POWEROFF_ON_AC="0"
defaults.conf L0039: BAY_POWEROFF_ON_BAT="0"
defaults.conf L0040: BAY_DEVICE="sr0"
/etc/tlp.conf L0349: RUNTIME_PM_ON_AC="auto"
defaults.conf L0042: RUNTIME_PM_ON_BAT="auto"
defaults.conf L0043: RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon"
defaults.conf L0044: USB_AUTOSUSPEND="1"
defaults.conf L0045: USB_EXCLUDE_AUDIO="1"
defaults.conf L0046: USB_EXCLUDE_BTUSB="0"
defaults.conf L0047: USB_EXCLUDE_PHONE="0"
defaults.conf L0048: USB_EXCLUDE_PRINTER="1"
defaults.conf L0049: USB_EXCLUDE_WWAN="0"
defaults.conf L0050: USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN="0"
defaults.conf L0051: RESTORE_DEVICE_STATE_ON_STARTUP="0"
defaults.conf L0052: RESTORE_THRESHOLDS_ON_BAT="0"
defaults.conf L0053: NATACPI_ENABLE="1"
defaults.conf L0054: TPACPI_ENABLE="1"
defaults.conf L0055: TPSMAPI_ENABLE="1"
/etc/tlp.conf L0044: TLP_DEFAULT_MODE="AC"
/etc/tlp.conf L0087: CPU_SCALING_GOVERNOR_ON_AC="powersave"
/etc/tlp.conf L0088: CPU_SCALING_GOVERNOR_ON_BAT="powersave"
/etc/tlp.conf L0136: CPU_BOOST_ON_AC="1"
/etc/tlp.conf L0137: CPU_BOOST_ON_BAT="1"
/etc/tlp.conf L0145: CPU_HWP_DYN_BOOST_ON_AC="1"
/etc/tlp.conf L0146: CPU_HWP_DYN_BOOST_ON_BAT="1"
/etc/tlp.conf L0169: PLATFORM_PROFILE_ON_AC="performance"
/etc/tlp.conf L0170: PLATFORM_PROFILE_ON_BAT="low-power"
+++ System Info
System = Framework AA Laptop
BIOS = 03.06
OS Release = Arch Linux
Kernel = 5.15.7-zen1-1-zen #1 ZEN SMP PREEMPT Wed, 08 Dec 2021 14:33:18 +0000 x86_64
/proc/cmdline = BOOT_IMAGE=/vmlinuz-linux-zen root=UUID=f389e8f0-aab6-43d2-beae-37ec0165907a rw rootflags=subvol=@ quiet cryptdevice=/dev/disk/by-uuid/b92f5a07-6428-49b1-b1d2-dcf878162684:root root=/dev/mapper/root resume=/dev/mapper/root resume_offset=1739377 rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 mem_sleep_default=deep
Init system = systemd
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = enabled
Last run = 10:22:17 AM, 180 sec(s) ago
Mode = battery
Power source = battery
Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
>>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
+++ Processor
CPU model = 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 4200000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = power [HWP.EPP]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1..cpu7: omitted for clarity, use -v to show all
/sys/devices/system/cpu/intel_pstate/status = active
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 9 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 100 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo = 0
/sys/devices/system/cpu/intel_pstate/hwp_dynamic_boost = 1
/sys/devices/system/cpu/intel_pstate/turbo_pct = 47 [%]
/sys/devices/system/cpu/intel_pstate/num_pstates = 39
/sys/module/workqueue/parameters/power_efficient = Y
/proc/sys/kernel/nmi_watchdog = 0
+++ Platform Profile
/sys/firmware/acpi/platform_profile = (not available)
/sys/firmware/acpi/platform_profile_choices = (not available)
+++ Temperatures
CPU temp = 42 [°C]
Fan speed = (not available)
+++ File System
/proc/sys/vm/laptop_mode = 2
/proc/sys/vm/dirty_writeback_centisecs = 6000
/proc/sys/vm/dirty_expire_centisecs = 6000
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
+++ Disks
Devices = nvme0n1 sda
/dev/nvme0n1:
Type = NVMe
Disk ID = nvme-nvme.144d-53324a354e583048383038313436-53414d53554e47204d5a564c56323536484348502d3030303030-00000001
Model = SAMSUNG MZVLV256HCHP-00000
Firmware = BXV7000Q
Temp = 43 °C
Scheduler = mq-deadline kyber [bfq] none (multi queue)
Runtime PM:
/sys/block/nvme0n1/power/control = auto, autosuspend_delay_ms = (not available)
SMART info:
Critical Warning: 0x00
Temperature: 43 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 2%
Data Units Written: 20,245,852 [10.3 TB]
Power Cycles: 4,151
Power On Hours: 3,992
Unsafe Shutdowns: 218
Media and Data Integrity Errors: 0
/dev/sda: not present.
+++ Intel Graphics
/sys/class/drm/card0/device/driver = i915
/sys/class/drm/card0/power/rc6_enable = 1 (enabled)
/sys/kernel/debug/dri/0/i915_fbc_status = FBC disabled: not supported with PSR2
/sys/kernel/debug/dri/0/i915_edp_psr_status = PSR mode: PSR2 enabled
/sys/class/drm/card0/gt_min_freq_mhz = 100 [MHz]
/sys/class/drm/card0/gt_max_freq_mhz = 1300 [MHz]
/sys/class/drm/card0/gt_boost_freq_mhz = 1300 [MHz]
/sys/class/drm/card0/gt_RPn_freq_mhz = 100 [MHz] (GPU min)
/sys/class/drm/card0/gt_RP0_freq_mhz = 1300 [MHz] (GPU max)
+++ Wireless
bluetooth = on
wifi = on
wwan = none (no device)
hci0(btusb) : bluetooth, not connected
wlp170s0(ath10k_pci) : wifi, connected, power management = on
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default performance powersave [powersupersave]
+++ PCIe Runtime Power Management
Enable devices = (disabled)
Disable devices = (disabled)
Device denylist = (disabled)
Driver denylist = mei_me nouveau radeon
/sys/bus/pci/devices/0000:00:00.0/power/control = auto (0x060000, Host bridge, no driver)
/sys/bus/pci/devices/0000:00:02.0/power/control = auto (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:04.0/power/control = auto (0x118000, Signal processing controller, proc_thermal)
/sys/bus/pci/devices/0000:00:06.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.1/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.2/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.3/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:08.0/power/control = auto (0x088000, System peripheral, no driver)
/sys/bus/pci/devices/0000:00:0a.0/power/control = auto (0x118000, Signal processing controller, intel-pmt)
/sys/bus/pci/devices/0000:00:0d.0/power/control = auto (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:0d.2/power/control = auto (0x0c0340, USB controller, thunderbolt)
/sys/bus/pci/devices/0000:00:0d.3/power/control = auto (0x0c0340, USB controller, thunderbolt)
/sys/bus/pci/devices/0000:00:12.0/power/control = auto (0x070000, Serial controller, intel_ish_ipc)
/sys/bus/pci/devices/0000:00:14.0/power/control = auto (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:14.2/power/control = auto (0x050000, RAM memory, no driver)
/sys/bus/pci/devices/0000:00:15.0/power/control = auto (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:15.1/power/control = auto (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:15.3/power/control = auto (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:16.0/power/control = auto (0x078000, Communication controller, no driver)
/sys/bus/pci/devices/0000:00:1d.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1f.0/power/control = auto (0x060100, ISA bridge, no driver)
/sys/bus/pci/devices/0000:00:1f.3/power/control = auto (0x040380, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:1f.4/power/control = auto (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:00:1f.5/power/control = auto (0x0c8000, Serial bus controller [0c80], intel-spi)
/sys/bus/pci/devices/0000:01:00.0/power/control = auto (0x010802, Non-Volatile memory controller, nvme)
/sys/bus/pci/devices/0000:aa:00.0/power/control = auto (0x028000, Network controller, ath10k_pci)
+++ USB
Autosuspend = enabled
Device allowlist = (not configured)
Device denylist = (not configured)
Exclude audio = enabled
Exclude bluetooth = disabled
Exclude phones = disabled
Exclude printers = enabled
Exclude WWAN = disabled
Bus 004 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 003 Device 003 ID 27c6:609c control = auto, autosuspend_delay_ms = 2000 -- Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC (no driver)
Bus 003 Device 002 ID 32ac:0002 control = auto, autosuspend_delay_ms = 2000 -- Framework HDMI Expansion Card (usbhid)
Bus 003 Device 004 ID 0cf3:e300 control = auto, autosuspend_delay_ms = 2000 -- Qualcomm Atheros Communications QCA61x4 Bluetooth 4.0 (btusb)
Bus 003 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Care
Plugin: generic
Supported features: none available
+++ Battery Status: BAT1
/sys/class/power_supply/BAT1/manufacturer = NVT
/sys/class/power_supply/BAT1/model_name = Framewo
/sys/class/power_supply/BAT1/cycle_count = (not supported)
/sys/class/power_supply/BAT1/charge_full_design = 3572 [mAh]
/sys/class/power_supply/BAT1/charge_full = 3571 [mAh]
/sys/class/power_supply/BAT1/charge_now = 3139 [mAh]
/sys/class/power_supply/BAT1/current_now = 666 [mA]
/sys/class/power_supply/BAT1/status = Discharging
/sys/class/power_supply/BAT1/charge_control_start_threshold = (not available)
/sys/class/power_supply/BAT1/charge_control_end_threshold = (not available)
Charge = 87.9 [%]
Capacity = 100.0 [%]
