It is possible to choose which graphics card to use... igpu or dgpu
It is possible to choose which graphics card to use… igpu or dgpu
For those of you who have a dedicated graphics card, is it possible to select in Windows which graphics card to use in each game or application?
Yes it is possible, there’s a windows setting for this
Windows is pretty good about selecting the most appropriate GPU but you can manually select it if desired
