BIOS Information
Vendor: INSYDE Corp.
Version: 03.06
Release Date: 10/02/2025
Which Framework Laptop 12 model are you using?
13th Gen Intel® Core™
Curious if anyone else has tried to get multiple language input working on the 12 in a way that the on-screen keyboard still works. So, I am trying to get Japanese input working and from my reading, the modern way to do it is using “fcitx5”.
Problem is, after switching the virtual keyboard to fcitx5, the on-screen keyboard function stops working, so I can not get a keyboard on the screen when in tablet mode. It appears to be a problem with fcitx because the on-screen keyboard works fine when switched back to the default “maliit” input.
It seems this is not a very common use, so I am having trouble finding any info on what is configured wrong. Is it just a limitation of wayland? Does X11 work? I may try installing X11 to try.
If anyone has been through this issue with trying to get fcitx5 working properly, I would love to know.
Reading this: Reddit - The heart of the internet (a post specifically about fcitx on wayland KDE), it seems that fcitx has to be started as a virtual keyboard, which may be what is missing in your setup. I do not know how to do this, but perhaps this gets you on the path you need?
I guess this is not technically an issue with the laptop itself but I’ve been having the same issue, on Fedora 43 KDE Plasma. A shame that Plasma Keyboard doesn’t work with fcitx5, really makes tablet mode almost unusable (if I also want to be able to type in Japanese with the physical keyboard).
Looks like I’ll also have to try fcitx5-osk, seems like it’s the only solution for now. Even though it looks like a very jank workaround to me, I appreciate that it exists.
