KB issue ive had forever
i’ve had an issue with the kb thinking it’s in function mode since release, (basically the function key is reversed) has anyone else encountered this, or has a solution? its not too bad, but i still wonder if its kb fw or a malfunction, or some other issue…
If you Press FN + Esc it will toggle the function button, so you instead get the F-keys by default instead of volume etc.
You’ll see it says “fn lock” on the escape key
