Labels for Port Capabilities
Those stickers look great.
Framework should offer stickers like that.
If I put them up on my etsy, what do you think I should charge for them?
Has anyone worked out what capabilities the USB ports have?
For example, Port 1 and 4 are USB4, but is that USB4-10, USB4-20, USB4-40 ?
I think it might be USB4-10 with USB4’s version of Thunderbolt 3 or maybe even Thunderbolt 4.
I.e. 10Gbps in USB mode, 40Gbps (32 real) in PCIe transport mode.
And the other ports are maybe USB 3.2 10Gbps and USB2.
Hard for me to say. It really depends on how much time & effort they take for you to make. And how valuable your spear time is.
Are they hand cut, or perhaps you own or have access to a laser cutter?
These were hand cut. Vynle is not good to cut with lasers, but I am getting access to a cricut, and if I find it works well I may pick up my own. I sell some 3d printed things I’ve designed, I just don’t know what stickers go for, so I was starting the process of market research :grin:.
following
I finally got a Cricut and figured out how to get it to cut the way I wanted, so the labels are up for sale! If you have any thoughts or questions, I’m always looking for feedback.
Labels on my Etsy Store.
Nice! Thanks for the design and Amazon link!!
Hey, OP here. I just wanted to update the thread with the current state of the printable sticker sheets that I put on a year ago. They’re mostly still attached, but some are peeling a little bit.
It doesn’t bother me too much though. The existence of the labels is still very helpful. Also I realized that the link that I posted to these designs had stopped working! so here’s an updated link
I wonder how difficult it would be to chemically etch these labels into the frame so they can’t come off.
It is probably easier to just laser etch them. These machines are quite affordable.
any chance you will make the same for 13?
And then you swap the mainboard and then they are wrong XD
He made some for the FW13. But the ports are labeled with 240W instead of the 100W the 13 supports. but thats a minor detail. But remember that the capabilities are only for the 7000 Ryzen Series.
I designed them myself, so I can edit them if they are incorrect, or if you want them to be different.
