Could be cleared but going from “power consumption” to charging output is a bit of a jump too, especially since it is a warning and I’d think a higher output charging capability would be a feature not a warning.
The root issue here is that the usb4 redrivers in the framework can’t sleep right with the usb-a cards connected which leads to higher idle consumption.
I definitely wasn’t able to get anything but 5V out of any of the ports but I guess you are right 5v negotiated over technically PD still counts as PD.
The USB-A port being present causes the retimers (chips that essentially retransmit USB4 signals with adjusted timings in order to improve signaling integrity, especially over longer cables) to get stuck in a state where they are constantly on unnecessarily, which causes the retimers to consume power and produce heat.
I don’t see it as a problem at all. But definitely something to be aware of. I would also expect it to change on new motherboard/cpu release combinations.
Except if you want to connect 3 USB-A devices to your laptop without using a USB HUB… Like, IDK, an external hard disk (or USB memory stick), a keyboard and a mouse. Or two of those things and a gamecontroller…
I assumed my default configuration for the Framework 13 AMD I ordered would be 1x USB-C (for charging) and 3x USB-A (for whatever I want to connect, I don’t have many USB-C devices, and those I do have use USB2), but apparently I should stick another adapter into the second USB4 port…
If I get a USB-C 3.0 connected USB Hub (or Cardreader/USB-Hub combo), and connect that to a USB-C 4 port of the laptop, will that cause the same power consumption issues?
