Hello everyone, the last weekend I was away and - for the first time after receiving my laptop - I didn’t use it for few days. Before leaving I powered it off (I’m using debian) and this morning when I tried to power it on it was not responding.
I plugged the usb-c cable to the monitor I usually use while at home and the charging led turned orange. I waited a minute or so and then I pushed the power button, the led lit immediately but the startup of the laptop (as in displaying the framework logo, so possibly the POST?) was slower than usual.
The OS detected the battery at 0%, so from the look of it the battery emptied itself over a weekend while powered off (I keep the maximum charge at 80% from the BIOS), this is a higher battery drain than the s0 suspension, so I guess there must be something very wrong somewhere.
This is the output of journalctl -b -1
, so from the OS point of view the shutdown state was properly reached:
feb 23 06:05:18 ferox systemd[1]: lvm2-monitor.service: Deactivated successfully.
feb 23 06:05:18 ferox systemd[1]: Stopped lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
feb 23 06:05:18 ferox systemd[1]: Reached target shutdown.target - System Shutdown.
feb 23 06:05:18 ferox systemd[1]: Reached target final.target - Late Shutdown Services.
feb 23 06:05:18 ferox systemd[1]: systemd-poweroff.service: Deactivated successfully.
feb 23 06:05:18 ferox systemd[1]: Finished systemd-poweroff.service - System Power Off.
feb 23 06:05:18 ferox systemd[1]: Reached target poweroff.target - System Power Off.
feb 23 06:05:18 ferox systemd[1]: Shutting down.
feb 23 06:05:18 ferox systemd-shutdown[1]: Syncing filesystems and block devices.
feb 23 06:05:18 ferox systemd-shutdown[1]: Sending SIGTERM to remaining processes...
feb 23 06:05:18 ferox systemd-journald[749]: Received SIGTERM from PID 1 (systemd-shutdow).
feb 23 06:05:18 ferox systemd-journald[749]: Journal stopped
Edit: information about the laptop model and connected expansion ports (no hardware was attached to the ports when powering off)
I’m using: a single usb-c expansion port (up left also towards the screen) and one usb-A in (lower-right also towards me).
The CPU is an AMD 7840u.
