[Linux] Audio popping when coming out of ALSA suspend
I have my speakers connected to the 3.5mm jack on my machine. I noticed a popping sound would happen after leaving sound off for a little bit. After some investigation, I found it was happening when the ALSA sink was in the SUSPENDED state (easy check by running pactl list short). I’ve been able to work around this issue by adding a wireplumber config with the “Matches all sinks” part of the example config from the fix found in the “Noticeable audio delay or audible pop/crack when starting playback” section of the PipeWire page on the ArchWiki.
This isn’t something I’ve needed to do on other machines. So my questions are:
  • Has anyone else encountered this problem?
  • Is there a chance there’s a problem with how the Framework Desktop handles ALSA suspend?
Thanks in advance!
Debian Testing
Which release version?
Last Updated: 2025-09-28
Which kernel are you using?
6.16.8+deb14-amd64
Up to date public (not beta/lvfs-testing) as of writing (Updating BIOS on Linux)
Which Framework Desktop model are you using? (AMD Ryzen™ AI Max 300 Series)
Ryzen™ AI Max+ 395 - 128GB
