I received my Batch 3 DIY FW16 7840HS on 8th March, but did not get to use it because of exams, except for installing openSuSe Tumbleweed on it, until now. I don’t remember the exact battery level, but when I last shut it down on 12th March, it had at least 60% battery remaining but today the battery was completely dead when I wanted to turn it on.
I had the following expansion cards:
Slot 1: USB-C
Slot 2: DisplayPort (2nd Gen)
Slot 3: Audio
Slot 4: USB-C
Slot 5: USB-C
Slot 6: USB-A
SSD: SK Hynix Gold P31 2TB
RAM: Kingston FURY Impact 64GB (32GB x 2)
I was wondering if someone else noticed how much battery does their FW16 lose after it is powered down?
Edited: Drain seems to be only in sleep mode, not when powered down.
So far as I know, it shouldn’t lose any, if it is completely powered down. There is a known problem with the battery draining in sleep mode though, were you using that instead of completely shutting it off?
I am almost sure it was completely powered down. I am doing another test today to know exactly how much, if any, the battery loses over time after shutdown.
I am afraid of some port combination or BIOS setting being the culprit.
I did 2 tests. One with powered down for 3 days and one with sleep in openSuSe.
With powered down, it lost 1% only, which could just be booting up variance.
While in sleep mode with lid closed as well, it lost more than 51% in 3 days. I can’t know exactly because after 3 days it was completely dead.
Is there any way to reduce this drain? At the moment there is some regression bug with power-profiles-daemon in openSuSe so it is not enabled. I will test it again when it is fixed.
