LMDE 6 Freezing On Boot
Which Linux distro are you using? LMDE 6
Which release version? Faye
Which kernel are you using? 6.1.0-37
Which BIOS version are you using? 3.05
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040 Series w/ dGPU
I’m having a problem with LMDE 6 “Faye” Cinnamon upon Boot. It freezes up after the login screen for about 3 minutes. Any help is appreciated.
Here is the logfile:
10:12:59 AM systemd: Failed to start nmbd.service - Samba NMB Daemon.
10:12:57 AM systemd: Timed out waiting for device dev-disk-by\x2duuid-0afb4a36\x2d8f23\x2d4f1b\x2d8842\x2d7d6f866b26f0.device - /dev/disk/by-uuid/0afb4a36-8f23-4f1b-8842-7d6f866b26f0.
10:11:38 AM lightdm: gkr-pam: unable to locate daemon control file
10:11:28 AM (uetoothd): sap-server: Operation not permitted (1)
10:11:28 AM (uetoothd): profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
10:11:28 AM (uetoothd): src/plugin.c:plugin_init() Failed to init bap plugin
10:11:28 AM (uetoothd): src/plugin.c:plugin_init() Failed to init mcp plugin
10:11:28 AM (uetoothd): src/plugin.c:plugin_init() Failed to init vcp plugin
10:11:27 AM kernel: amdgpu 0000:c5:00.0: firmware: failed to load amdgpu/gc_11_0_1_mes_2.bin (-2)
10:11:27 AM kernel: r8152 2-1:1.0 (unnamed net_device) (uninitialized): netif_napi_add_weight() called with weight 256
10:11:27 AM kernel: amdgpu 0000:03:00.0: firmware: failed to load amdgpu/gc_11_0_2_mes_2.bin (-2)
10:11:27 AM kernel: firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
And my System Info:
System:
  Kernel: 6.1.0-37-amd64 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0 Desktop: Cinnamon v: 6.4.8
    tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM v: 1.26.0 Distro: LMDE 6 Faye
    base: Debian 12.1 bookworm
Machine:
  Type: Laptop System: Framework product: Laptop 16 (AMD Ryzen 7040 Series) v: AG
    serial: <superuser required> Chassis: type: 10 v: AG serial: <superuser required>
  Mobo: Framework model: FRANMZCP07 v: A7 serial: <superuser required> UEFI: INSYDE v:             03.05
    date: 11/13/2024
Battery:
  ID-1: BAT1 charge: 64.1 Wh (80.1%) condition: 80.0/85.1 Wh (94.0%) volts: 16.8 min: 15.5
    model: NVT FRANDBA type: Li-ion serial: <filter> status: charging cycles: 51
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510 serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
CPU:
  Info: 8-core model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64 type: MT MCP smt: enabled
    arch: Zen 4 rev: 1 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
  Speed (MHz): avg: 1431 high: 3800 min/max: 1600/3800 boost: enabled cores: 1: 566 2: 1600
    3: 3800 4: 1600 5: 730 6: 1406 7: 551 8: 1348 9: 1600 10: 1600 11: 812 12: 888 13: 1600 14: 1600
    15: 1600 16: 1600 bogomips: 121371
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: AMD Navi 33 [Radeon RX 7700S/7600S] vendor: Framework driver: amdgpu v: kernel
    arch: RDNA-3 pcie: speed: 16 GT/s lanes: 8 ports: active: none empty: DP-1,eDP-1 bus-ID: 03:00.0
    chip-ID: 1002:7480 class-ID: 0300
  Device-2: AMD Phoenix1 vendor: Framework driver: amdgpu v: kernel arch: RDNA-3 pcie:
    speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8,
    DP-9 bus-ID: c5:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 46.0 C
  Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.9 driver: X: loaded: amdgpu
    unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52") s-diag: 599mm (23.6")
  Monitor-1: eDP-2 mapped: eDP-1 model: BOE Display 0x0bc9 res: 1920x1200 hz: 165 dpi: 141
    size: 345x215mm (13.58x8.46") diag: 407mm (16") modes: max: 2560x1600 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon Graphics (gfx1103_r1 LLVM 15.0.6 DRM 3.49
    6.1.0-37-amd64) direct-render: Yes
Audio:
  Device-1: AMD Navi 31 HDMI/DP Audio vendor: Framework driver: snd_hda_intel v: kernel pcie:
    speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Framework driver: snd_hda_intel
    v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: c5:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Framework driver: N/A pcie:
    speed: 16 GT/s lanes: 16 bus-ID: c5:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: Framework driver: snd_hda_intel v: kernel pcie:
    speed: 16 GT/s lanes: 16 bus-ID: c5:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.0-37-amd64 status: kernel-api
  Server-1: PipeWire v: 0.3.65 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
  Device-1: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800] vendor: Quectel Wireless
    Solutions driver: N/A pcie: speed: 8 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 17cb:1107
    class-ID: 0280
  Device-2: Realtek USB 10/100/1G/2.5G LAN type: USB driver: r8152 bus-ID: 2-1:2
    chip-ID: 0bda:8156 class-ID: 0000 serial: <filter>
  IF: enx9cbf0d004f97 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: Quectel Wireless Solutions type: USB driver: btusb v: 0.8 bus-ID: 1-5:7
    chip-ID: 2c7c:0130 class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
Drives:
  Local Storage: total: 2.75 TiB used: 66.02 GiB (2.3%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WD PC SN740 SDDPTQD-1T00 size: 953.87 GiB
    speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 73110000 temp: 43.9 C scheme: GPT
  ID-2: /dev/nvme1n1 vendor: Western Digital model: WD BLACK SN770 1TB size: 931.51 GiB
    speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 731100WD temp: 41.9 C scheme: MBR
  ID-3: /dev/sda type: USB model: FRMW 1TB Card size: 931.51 GiB type: N/A serial: <filter>
    rev: PMAP scheme: MBR
Partition:
  ID-1: / size: 906.38 GiB used: 66.01 GiB (7.3%) fs: ext4 dev: /dev/dm-0 mapped: lvmlmde-root
  ID-2: /boot/efi size: 285.4 MiB used: 5.8 MiB (2.0%) fs: vfat dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: partition size: 30.66 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
    mapped: lvmlmde-swap
USB:
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 5 rev: 2.0 speed: 480 Mb/s
    chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 05e3:0610
    class-ID: 0900
  Device-1: 1-2.3:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Hub-3: 1-3:3 info: Genesys Logic Hub ports: 3 rev: 2.0 speed: 480 Mb/s power: 100mA
    chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-3.2:6 info: Framework Laptop 16 Numpad Module type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.1 speed: 12 Mb/s power: 500mA chip-ID: 32ac:0014
    class-ID: 0300 serial: <filter>
  Hub-4: 1-4:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA
  Device-1: 1-4.1:8 info: Shenzhen Goodix Fingerprint USB Device type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 27c6:609c class-ID: ef00
    serial: <filter>
  Device-2: 1-4.2:9 info: Framework Laptop 16 Keyboard Module - ANSI type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.1 speed: 12 Mb/s power: 500mA chip-ID: 32ac:0012
  Device-3: 1-5:7 info: Quectel Wireless Solutions type: Bluetooth driver: btusb interfaces: 2
    rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 2c7c:0130 class-ID: e001
  Hub-5: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
    class-ID: 0900
  Device-1: 2-1:2 info: Realtek USB 10/100/1G/2.5G LAN type: Network driver: r8152 interfaces: 1
    rev: 3.2 speed: 5 Gb/s power: 256mA chip-ID: 0bda:8156 class-ID: 0000 serial: <filter>
  Hub-6: 2-2:3 info: Genesys Logic USB3.2 Hub ports: 3 rev: 3.2 speed: 10 Gb/s chip-ID: 05e3:0625
    class-ID: 0900
  Device-1: 2-2.2:4 info: Framework 1TB Expansion Card type: Mass Storage driver: uas
    interfaces: 1 rev: 3.2 speed: 10 Gb/s power: 896mA chip-ID: 32ac:0005 class-ID: 0806
    serial: <filter>
  Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s
  Hub-8: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-9: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s
  Hub-10: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-11: 7-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s
  Hub-12: 8-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
    class-ID: 0900
Sensors:
  System Temperatures: cpu: N/A mobo: N/A
  Fan Speeds (RPM): N/A
  GPU: device: amdgpu temp: 47.0 C device: amdgpu temp: 48.0 C mem: 46.0 C fan: 0 watts: 27.00
    V: 5.00
Repos:
  Packages: 2622 pm: dpkg pkgs: 2580 pm: flatpak pkgs: 42
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
    1: deb https: //mirror.rackspace.com/linuxmint/packages faye main upstream import backport
    2: deb http: //debian.csail.mit.edu/debian bookworm main contrib non-free non-free-firmware
    3: deb http: //debian.csail.mit.edu/debian bookworm-updates main contrib non-free non-free-firmware
    4: deb http: //security.debian.org/ bookworm-security main contrib non-free non-free-firmware
    5: deb http: //debian.csail.mit.edu/debian bookworm-backports main contrib non-free non-free-firmware
  Active apt repos in: /etc/apt/sources.list.d/spotify.list
    1: deb http: //repository.spotify.com stable non-free
Info:
  Processes: 361 Uptime: 20m wakeups: 12 Memory: 30.66 GiB used: 2.69 GiB (8.8%) Init: systemd
     v: 252 target: graphical (5) default: graphical Compilers: gcc: 12.2.0 alt: 12 Client: Cinnamon
 v: 6.4.8 inxi: 3.3.26
The missing firmware might definitely be an issue; IDK how it is for Mint but they’re pointing you to this resolution for how to get the firmware if you were on Debian, which might be a starting point:
There are also GPU crashes in the AMD driver that’s in the standard kernel. IDK if it’s related to your issue or not, but if you’re comfortable compiling your own kernel I had good results fixing system freezes by replacing the kernel with this:
Those were more intermittent than what you’re describing though. You might start with trying to track down how to get it to load new firmware and see what that does.
