Hi,
I’m trying to determine whether this is a firmware issue or expected behavior.
The system startup to display the framework logo depends on how I have my computer connected to the monitor
systemd-analyze:
Startup finished in 11.056s (firmware) + 340ms (loader) + 1.140s (kernel) + 71ms (initrd) + 4.263s (userspace) = 16.872s
So normal boot is 11s.
case 1. DP or HDMI direct to Monitor
11s
case 2. Thunderbold direct to Monitor
40-50s
case 3. OCuLink → DP → Monitor
40-50s
case 4. Both Dp-> monitor and OCuLink → DP → Monitor
12s
It looks like the firmware waits for an active display on the integrated GPU, or there is a timeout while initializing DisplayPort Alt Mode / eGPU before POST continues.
The operating system is not involved, because only the firmware time changes.
Has anyone observed similar behavior on the Framework Desktop?
I’m also considering testing with an HDMI dummy plug to see whether presenting a “fake” monitor on the iGPU makes firmware boot fast again.
Any ideas or similar experiences would be appreciated.
