Losing 25%/hour
Fedora
Which release version?
Fedora 43
Which kernel are you using?
Linux 6.18.9-200.fc43.x86_64
03.04
AMD Ryzen™ AI 300 9 hx 370
64GB RAM
2 TB SSD
I just coded some things in my Kotlin IDE and when Suspending & Folding the Laptop I lost 25% during one hour and the laptop got hot in the center (I guess it’s where the CPU is). I looked up some posts but most mention like 3%/4% drain/hour so I thought this might be a different issue.
Any error messages in dmesg output at a terminal?
Use your preferred technique to launch a bash session. Paste this at the prompt:
while true ; do before=$(date +%s); sleep 15; after=$(date +%s); [[ $((after - before)) -gt 17 ]] && echo discontinuity; done
Under normal circumstances it should tun forever and not produce output.
Suspend your FW13 in the usual manner. Wake it up again after more than 30 seconds.
If the word “discontinuity” does not subsequently get written to your bash session you can be certain your FW13 is not actually being suspended.
Use an interrupt (usually Ctrl-C) to terminate the loop.
I get a ton but since I am very new to linux/fedora dont understand really anything (also in terms of what is considered normal): Here is a part of the output (I could post everything):
[ 5595.564207] queueing ieee80211 work while going to suspend
[ 5595.645743] PM: suspend devices took 0.098 seconds
[ 5595.654468] ACPI: EC: interrupt blocked
[ 5661.910343] ACPI: EC: interrupt unblocked
[ 5662.271743] [drm] PCIE GART of 512M enabled (table at 0x0000008001700000).
[ 5662.271820] amdgpu 0000:c1:00.0: amdgpu: SMU is resuming…
[ 5662.276070] amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
[ 5662.280059] nvme nvme0: 24/0/0 default/read/poll queues
[ 5662.328436] amdgpu 0000:c1:00.0: amdgpu: [drm] Applying panel backlight quirk, min_brightness: 0
[ 5662.329138] amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 5662.329141] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 5662.329143] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 5662.329144] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 5662.329145] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 5662.329146] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 5662.329147] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 5662.329148] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 5662.329149] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 5662.329150] amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 5662.329151] amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 5662.329153] amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec_0 uses VM inv eng 1 on hub 8
[ 5662.329154] amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[ 5662.329155] amdgpu 0000:c1:00.0: amdgpu: ring vpe uses VM inv eng 4 on hub 8
[ 5662.426139] PM: resume devices took 0.159 seconds
[ 5662.426817] OOM killer enabled.
[ 5662.426818] Restarting tasks: Starting
[ 5662.429201] Restarting tasks: Done
[ 5662.429217] efivarfs: resyncing variable state
[ 5662.435498] efivarfs: finished resyncing variable state
[ 5662.435542] random: crng reseeded on system resumption
[ 5662.442091] PM: suspend exit
[ 5662.964872] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
[ 5663.252503] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
[ 5665.078504] wlp192s0: VHT information is missing, disabling VHT
[ 5665.126163] wlp192s0: authenticate with 34:31:c4:6b:da:4e (local address=7e:d3:3c:ad:f9:6f)
[ 5665.489414] wlp192s0: send auth to 34:31:c4:6b:da:4e (try 1/3)
[ 5665.496018] wlp192s0: authenticated
[ 5665.500317] wlp192s0: associate with 34:31:c4:6b:da:4e (try 1/3)
[ 5665.542330] wlp192s0: RX AssocResp from 34:31:c4:6b:da:4e (capab=0x411 status=0 aid=1)
[ 5665.582570] wlp192s0: associated
[ 5665.585811] wlp192s0: Limiting TX power to 20 (23 - 3) dBm as advertised by 34:31:c4:6b:da:4e
[ 5748.874645] usb 1-1: reset full-speed USB device number 2 using xhci_hc
[ 5749.139609] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
→ while true ; do before=$(date +%s); sleep 15; after=$(date +%s); [[ $((after - before)) -gt 17 ]] && echo discontinuity; done
output:
discontinuity (only once)
That tells you that your FW13 was actually suspended for at least some of the time the lid was closed.
Did the other symptoms–unexpected battery depletion and heat–recur?
We could refine that loop to reveal the length of the discontinuity. You could then reconcile that with the time the lid was closed. Does that seem useful?
Hello guys. Maybe that’s some relevant information:
I just had another hard freeze/system freeze (display’s still on but nothing happens and sometimes shiftkeylock key blinks). This time it occured during LibreWolf (Firefox Privacy Fork). I have then for like 3 Months now.
Also I set up dualboot with windows on my Laptop…
If this issue is unrelated to my battery I would change the thread/create a new one
Here is the output of a command that ChatGPT told me to do:
 sudo journalctl -b -1 -p err..emerg --no-pager
(0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:12 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: postConnectProcessing File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2275 Invoked Function: ::connect Return Code: 113 (0x00000071) Description: unknown
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/TlsTransport.cpp Line: 477 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/HttpSessionAsync.cpp Line: 1444 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 289 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: callbackHandler File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2128 Invoked Function: CSocketTransport::postConnectProcessing Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: TestNetworkAccess File: ../../vpn/Agent/NetEnvironment.cpp Line: 1777 Invoked Function: CNetEnvironment::analyzeHttpResponse Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1046 Invoked Function: CNetEnvironment::TestNetworkAccess Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
Mar 03 02:36:14 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: TestNetEnv File: ../../vpn/Agent/NetEnvironment.cpp Line: 436 Invoked Function: CNetEnvironment::testNetwork Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
Mar 03 02:36:19 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: postConnectProcessing File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2275 Invoked Function: ::connect Return Code: 101 (0x00000065) Description: unknown
Mar 03 02:36:19 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/TlsTransport.cpp Line: 477 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:19 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/HttpSessionAsync.cpp Line: 1444 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:19 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 289 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 02:36:19 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: callbackHandler File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2128 Invoked Function: CSocketTransport::postConnectProcessing Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 12:28:28 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 12:28:31 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: internalReadSocket File: ../../vpn/Common/IPC/UdpTcpTransports_unix.cpp Line: 570 Invoked Function: ::read Return Code: 104 (0x00000068) Description: unknown
Mar 03 12:28:31 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: callbackHandler File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2098 Invoked Function: CSocketTransport::internalReadSocket Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ Local Addr: [100.72.215.215]:40548, Remote Addr: [139.6.0.5]:443
Mar 03 12:28:31 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnSocketReadComplete File: ../../vpn/Common/IP/TlsTransport.cpp Line: 625 Invoked Function: ISocketTransportCB::OnSocketReadComplete Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ
Mar 03 12:28:31 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/HttpSessionAsync.cpp Line: 1444 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ
Mar 03 12:28:31 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 289 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ
Mar 03 12:28:41 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: internalReadSocket File: ../../vpn/Common/IPC/UdpTcpTransports_unix.cpp Line: 570 Invoked Function: ::read Return Code: 104 (0x00000068) Description: unknown
Mar 03 12:28:41 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: callbackHandler File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2098 Invoked Function: CSocketTransport::internalReadSocket Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ Local Addr: [100.72.215.215]:45138, Remote Addr: [139.6.0.4]:443
Mar 03 12:28:41 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnSocketReadComplete File: ../../vpn/Common/IP/TlsTransport.cpp Line: 625 Invoked Function: ISocketTransportCB::OnSocketReadComplete Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ
Mar 03 12:28:41 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/HttpSessionAsync.cpp Line: 1444 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ
Mar 03 12:28:41 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 289 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588342 (0xFE1E000A) Description: SOCKETTRANSPORT_ERROR_READ
Mar 03 12:28:49 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 12:29:06 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1017 Invoked Function: CNetEnvironment::testDnsAccess Return Code: -28901362 (0xFE47000E) Description: NETENVIRONMENT_ERROR_DNS_RESOLUTION_FAILED:Domain name resolution of the host targeted by the network probe has failed
Mar 03 12:29:06 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: TestNetEnv File: ../../vpn/Agent/NetEnvironment.cpp Line: 436 Invoked Function: CNetEnvironment::testNetwork Return Code: -28901362 (0xFE47000E) Description: NETENVIRONMENT_ERROR_DNS_RESOLUTION_FAILED:Domain name resolution of the host targeted by the network probe has failed
Mar 03 12:29:39 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 12:29:40 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 366 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:29:40 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:29:40 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:30:20 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 12:30:21 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1017 Invoked Function: CNetEnvironment::testDnsAccess Return Code: -28901362 (0xFE47000E) Description: NETENVIRONMENT_ERROR_DNS_RESOLUTION_FAILED:Domain name resolution of the host targeted by the network probe has failed
Mar 03 12:30:21 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: TestNetEnv File: ../../vpn/Agent/NetEnvironment.cpp Line: 436 Invoked Function: CNetEnvironment::testNetwork Return Code: -28901362 (0xFE47000E) Description: NETENVIRONMENT_ERROR_DNS_RESOLUTION_FAILED:Domain name resolution of the host targeted by the network probe has failed
Mar 03 12:30:44 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 12:30:44 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: applyHostConfigForNoVpn File: ../../vpn/Agent/MainThread.cpp Line: 14413 Invoked Function: CHostConfigMgr::DeterminePublicInterface Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
Mar 03 12:30:44 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTimerExpired File: ../../vpn/Agent/MainThread.cpp Line: 7877 Invoked Function: CMainThread::applyHostConfigForNoVpn Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
Mar 03 12:30:53 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: postConnectProcessing File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2275 Invoked Function: ::connect Return Code: 113 (0x00000071) Description: unknown
Mar 03 12:30:53 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/TlsTransport.cpp Line: 477 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 12:30:53 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnTransportInitiateComplete File: ../../vpn/Common/IP/HttpSessionAsync.cpp Line: 1444 Invoked Function: ISocketTransportCB::OnTransportInitiateComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 12:30:53 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 289 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 12:30:53 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: callbackHandler File: ../../vpn/Common/IPC/SocketTransport.cpp Line: 2128 Invoked Function: CSocketTransport::postConnectProcessing Return Code: -31588340 (0xFE1E000C) Description: SOCKETTRANSPORT_ERROR_CONNECT
Mar 03 12:31:13 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: TestNetworkAccess File: ../../vpn/Agent/NetEnvironment.cpp Line: 1777 Invoked Function: CNetEnvironment::analyzeHttpResponse Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
Mar 03 12:31:13 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1046 Invoked Function: CNetEnvironment::TestNetworkAccess Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
Mar 03 12:31:13 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: TestNetEnv File: ../../vpn/Agent/NetEnvironment.cpp Line: 436 Invoked Function: CNetEnvironment::testNetwork Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
Mar 03 12:31:25 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 366 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:31:25 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:31:25 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:34:41 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 12:34:42 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 366 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:34:42 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:34:42 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:34:48 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 366 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:34:48 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:34:48 FW13 csc_vpnagent[1299]: [TID=-565205312] Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
Mar 03 12:36:29 FW13 systemd-udevd[817]: nvme0: Worker [54781] processing SEQNUM=32172 killed.
Mar 03 12:36:29 FW13 systemd-udevd[817]: 1-1: Worker [54784] processing SEQNUM=32183 killed.
Mar 03 12:36:29 FW13 systemd-udevd[817]: card1: Worker [54782] processing SEQNUM=32173 killed.
Mar 03 12:37:09 FW13 gdm-password][56385]: gkr-pam: the password for the login keyring was invalid.
Mar 03 12:37:10 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
Mar 03 12:37:19 FW13 wpa_supplicant[2005]: bgscan simple: Failed to enable signal strength monitoring
(The output is longer containing information from yesterday but I had to crop it bc. of the 32k limit)
Ah I see. I also doublechecked with the power statistics app and it also showed no usage data points during lid closed/suspend
I would adapting the script and check again. I started to shut down my laptop bc I didn’t want to harm the battery too much so I dunno how it has been so far
I tweaked the script so it will output the times of day that bookend suspension.
while true ; do before=$(date +%s); sleep 15; after=$(date +%s); [[ $((after - before)) -gt 17 ]] && echo "discontinuity: $(date -d @$before) -> $(date -d @$after)"; done
In an earlier (and now unavailable) post @Imran_Bin_ilias mentioned hardware sub-systems that do not quiesce on demand and continue to provoke processor activity leading to battery drain and elevated temperature.
If your laptop is experiencing that problem it seems possible that the DE could be suspended while the lower-level activity continues. Were that the case, the script would reflect DE suspension rather than an SSD that doesn’t suspend correctly.
With respect, I don’t think it reasonable to ask forum contributors to interpret the output of a command line suggested by a chat bot without knowing what the bot was asked or how that relates to “losing 25%/hour”.
I just want to bump this issue. I am running into this, with very high battery drain during s2idle suspend, on a Ryzen 7040U.
My kernel version is 6.19.5
I suspect my recent update to BIOS 3.18
I can confirm through my system logs that my laptop is actually remaining in suspend during this battery drain.
I might also note that I attempted to switch to S3/deep sleep to resolve this, which my laptop fails to even enter, logs citing some opaque “dependency error”.
Truffaldino I totally agree with you last statement and I am sorry for my bad skills and high demands – I was/am pretty lost and frustated (since I paid like a lot) and just wanted a quick fix leading me to just post and outsource the thinking to others. I’ll be more mindful in the future about providing context and asking clearer questions (which is also not very easy for me bc I am pretty new to Linux, which obviously is not a reason not to provide it :P). I really do appreciate everyone’s time and expertise!
Did you check if S3/deep is actually availabe for you laptop? BC I know that they removed it on the newer ones. You can check it with cat /sys/power/state or cat /sys/power/mem_sleep
Not sure, someone from FW might be able to say whether the Ryzen 7040U has support for S3 sleep.
My issue is mostly unrelated to that, since the excessive power consumption is all during s2idle sleep.
So I’ve got a suspicion: I installed the GNOME Plugin “Caffeine” which prevents the Laptop from suspending when activated. The issue might be related to this feature. The reason why I suspect this feature to be a potential cause is the fact that I turned it off before going to be tonight and “only” lost 5-8% during 7 hours which seems to be quite reasonable.
I’ll run truffaldinos script a few times during the next days paired with deactivating the GNOME Addon to check if it’s really true.
I tested the discontinuity tonight (with the addon disabled) and it seems like my system is suspending.
while true ; do before=$(date +%s); sleep 15; after=$(date +%s); [[ $((after - before)) -gt 17 ]] && echo “discontinuity: $(date -d @$before) → $(date -d @$after)”;
donediscontinuity: Thu 5 Mar 00:45:40 CET 2026 → Thu 5 Mar 10:15:46 CET 2026
I lost about 8% during these 10 hours and the center of the laptop didn’t get warm/hot which is a lot more reasonable than before.
I’ll continue testing. Thank you for your support so far!
It seems that are still some problems.
I’ll continue searching what the reason might be.
Also: Every time after using my laptop I get an electric shock when touching metal… Idk if it has something to do with that but it’s weird
There is a regression in 6.19.4 that was fixed in 6.19.6. it was an LLM backported patch that shouldn’t have been.
There was a separate regression in Linux firmware around the same time.
6.19.6 + latest Linux firmware should be in good shape.
