Hi Framework, i had an interesting idea (for my point of view), what if the next gen laptops had the components accesible from the back? since i like moding my things that way it will be easier to add more thing, now that is going in trend bifurcating the m.2 slot and since 4.0 x2 is more than enought for more of the things, that is why it will be posible to expand the storage easyer, if amd has that option of course, but since n100 has it, i asume that in case they dont have it, will be posible, or even pack more than just nvme´s, and since it will be on the back, for the people that want to go cryze, they can print a custom back cover,
- it also will allow to go custom cooling and make 3er party make overkill custom cooling or wc for more silence gaming, ML, rendering, whatever the case that takes it to the limit.
- 3er party bifier gpu
- A battery expansion will also be posible
- And tacking about cooling, why not implementing a server like cooling ideology, i mean instead of letting the fans sucking air direct from the outside, let them suck it from the inside and put the intake on the front, that why not only the memory, nvme ant other components will benefit from it, also the keyboard wont be warm, in adition will be posible to have a mesh on the fron to avoid sucking dirt and therefore not having the anoying problem of having the heatsink stuck and the inmidiatly overheating
